- Replies 35
- Views 8.7k
MnTom 4 posts
Wild and Free 4 posts
klcammie 2 posts
CTcummins24V 2 posts
After posting and debating on the use of an additive in diesel fuel in a different thread. Maybe we should share our practices to help each other out. I know this can be a very argumentative subject. Point is many of us have had our trucks from times when quality and selection of products wasn't so great. We all know diesel fuel has taken a dive in quality over the years but IMO engine oils and such have made drastic improvements. Some of us have products and services at our disposal that others don't.
I own two Cummins powered 2nd gens.
1997 12 Valve - 220,000 miles on the clock - 180,000 of those under this practice. Rotella T6 5W40 oil with a LF16035 oil filter. Every 7,500 miles - grease job, fuel filter, oil filter, and oil analysis. At 15,000 miles grease job, fuel filter, oil change, oil filter, and oil analysis. Oil analysis always has had very low wear metal levels and nearly no contamination. TBN is always above 7 when changing the oil at 15,000.
2001 24 Valve - 113,000 miles on the clock - 27,000 of those under this practice. Delvac LE 5W30 oil with LF16035 oil filter. Every 7,500 miles - grease job, oil filter, and oil analysis. At 15,000 miles grease job, fuel filter, oil change, oil filter, and oil analysis. Oil analysis always has had very low wear metal levels and nearly no contamination. TBN is always above 7 when changing the oil at 15,000. Granted I'm only on my second synthetic oil change with this truck my experience with the 12 Valve is leading me to follow the same practice.
Neither truck has ever had any sort of additive in the oil or diesel fuel since I've owned them. Another practice I follow when making decisions on oil for these trucks is if the current Cummins spec CES 20081 is listed on the bottle.
I am not a fan of marketed oils such as Amsoil, Lucas, or anything claiming to be the cure all. Seeing is believing for me and many products have fell short of that in my view. I know Amsoil has a synthetic classification of IV to the Rotella T6 and Delvac LE class III synthetic classification but I have seen too many bad oil analysis showing high copper and iron readings on customer vehicles using Amsoil.
Edited by 04Mach1
