Where to get an ECU?
- Replies 38
- Views 10.3k
RPM 8 posts
Yankneck696 8 posts
CSM 5 posts
hodag56 4 posts
For the second time in three years I believe my ECU is headed south. A few weeks ago the truck didn't want to start. I checked the grid heater and had more than the recommended resistance between the terminals. I had power to the relays with the wait to start light just no power coming out. Fusible links are good.
Now the problem as I understand it is I have 12 volts to the relays with the wait to start light on. When the wait light goes out, I should have zero volts to the relays. I have seven. If I have more than zero it sould be the ECU according to the service manual. I now have IAT sensor voltage codes, fuel calibration error codes, etc.
Now the million dollar question. I bought a used ECU the last time and blew in a program with the smarty. I would like something to last longer than a couple of years. I know people have said to stay away from a re-manfactored ECU. Dodge tells me they only sell a reman ECU's now, nothing new. They go for the tune of $1400.00 not programmed. I have heard ECU's going south after a short time from Dodge. What is the difference between a Dodge re-man and a $800.00 model from a company off the net? I know to stay away from a Cardone. Also, what about these companies like Klien Bottle Computer who give you a lifetime warentee if they rebuild your ECU?
Anyone care to weigh in?
