High Idle Kits
The high idle kits are going to handed back to me for production. All future production of the Mopar1973Man.Com High Idle Kits will be produced right here in Idaho. As soon as I get all the parts and pieces from Ed Grafton (Yankneck696) I'll start producing them. So I know some of you are hoping for more to be produced and seeing DAP running out of the flat mount version. So hang in there more to come very very soon.
  • Replies 24
  • Views 6.4k
  • Good to hear Mike,      As for the issue unplug the switch and see if the issue comes back.
    Sorry CSM. Unless you wait a while and for me to build the new ones and the by a second one you can have a Idaho built high idle kit.
I would get the setup.
The MPG mode will pay for the cost of the switch, depending on how much you drive, pretty quickly.
High idle can be used for more than just warming up the truck too.  For prolonged idling it comes in very handy.
Like me78569 said, the switch is very useful! I woke up this morning to 12 degrees and it had my truck at 100 in no time. I also set it to high idle when I run into the convenience store, and it continues to warm the engine up. Oh and I think I gained minimum of 1mpg during the winter with the MPG feature.
This is good stuff! I daily drive mine and my commute is about 7 miles one way, so on colder days it's practically impossible to get the temp gauge off the bottom peg. Sounds like this might be a good way to safely speed that up right?!
  • 7 months later...
Right now the big problem is getting the site stable... First. Then I can move back to the high idle mod and get the stuff going with Ed. But I'm way behind with the server being too small and still need to install a better store software which is half done now. But I'll get back to High Idle stuff a bit later...
 Michael Nelson - I have been checking the store (http://store.mopar1973man.com/index.php/high-idle-kits.html) for a few months trying to be patient, however do you have an ETA on when the High Idle kits will be available again?
  • 3 months later...
