Decided to build a replacement center console for my 2000. It started when I could not find a suitable place to install my switch panel for the airbag inflation switch's and gauge. So I removed the center console and built a mock up out of cardboard and went from there. The cardboard mockup was 4 inches longer than the wooden one. I decided to attach the CB to the front of it.
I ended up with a console 14" wide x 17" long x 15" on the back side(passenger side). It is 9" high on the drivers side and makes a nice arm rest. The panel is going to 16 gauge steel. I have to finalize the gauge layout and cut out the rough holes with the plasma cutter.
I picked up some fabric that is a little darker than I like but it was the closest thing I could find. I am moving 3 switches to the console right now and the Pacbrake air bag controls. I wanted something I can add more to in the future. I will post more as I go. Plan to work on it a little during the week since I brought it in the house out of the cold. I also removed the seat belt for the center seat.
1
