Alright guys little story behind this... I left the mountain from snowmobiling today and about 20min into the drive I started the long trek up the 7% grade 5 miles long at 11,000ft elevation. By the time I got to the bottom of the grade my thermostat had obviously opened (Saw temps rise to 195 then backed down to 190). So, doing 70 with the EGTs at 1,100 degrees constant I look down and see the water temp rising... usually this is normal and it creeps to 195-197 then settles right in that area. This time it kept rising and topped out at 209. It then held that for about a mile, then dropped down to 195 and didn't rise again the rest of the way up the mountain. I don't think this is normal... Is my thermostat failing??
