  • Replies 10
  • Views 3.2k
  •     The urls have changed.  You can use the search function to find most everything still.
  • 11 months later...
Thanks for the quick reply.  I must not be as web smart as you.  I still can not find it and don't dare to attempt a rebuild without seeing it.   I've currently got a pretty good drip where the hydroboost and master cyl come together
Definitely rebuild. I bought a reman unit...waste of money. You have to take parts off your old hydroboost anyways and transfer them to the "new" unit, like the mounting bracket and spring.
  • 3 years later...
On 4/18/2015 at 1:00 AM, Mopar1973Man said:
Hello,
Do you happen to know the Part Number for the seal that goes between the reservoir and the pump. I have attached a picture for your reference. I ordered a kit that brought the seal inside the pump and the figure 8 but it was missing this one that goes in the groove the reservoir has.
Parts manual shows it as:  Seal, master cylinder to booster   Dodge 04723395  (item 6)
