- Replies 15
- Views 5.8k
JAG1 5 posts
Mopar1973Man 3 posts
Killer223 3 posts
joecool911 2 posts
When I first built my small cabin I stained it for color then applied teak oil.
After the teak oil, I mixed 50 50 paint thinner and exterior varnish. The thought was varnish would be thin enough to do a good soaking into the wood grain and not cause a pealing flaking problem in the future, requiring the need for excessive work on sanding and refinishing10 years down the road.
However, after talking with a log home inspector, he told me that if he finds a log home that has been varnished that he would turn down the entire sale of the property and should never, ever varnish a log home. That moisture gets under the varnish and starts rotting the logs with mold.
Well 20 years has gone by and as I started using his recommended oils, not varnish this time around, I find the oil seams to eventually dry out and allow a raw wood look that starts to mold on the surface like an untreated deck. I say this with the information that my original 50 50 varnish mix did not ever peal nor get mold underneath the finish. It just sort of weathered away and never ever pealed nor crystallized like some varnishes when they age. I'll say it again.... It just weathered away with never a mold or pealing problem.
I want to go back to the 50 50 mix again because it lasted at least 10 yrs and made the home look great.
What are your folks experience? Have you ever finished exterior wood with success?
Thanks for any thoughts.
