  1. Not going to make any gains... Timing is the ultimate EGT control once you understand how timing works. BHAF with 110℉ summer temperatures and still hold 700℉ EGT's at 82 MPH twisting 2,500 RPM in 5th gear.
  2. TSB 18-006-12 - Diagnostic Enhancements For Fuel System THIS BULLETIN SUPERSEDES SERVICE BULLETIN 18-011-11 REV. B., DATED JULY 1, 2011, WHICH SHOULD BE REMOVED FROM YOUR FILES. ALL REVISIONS ARE HIGHLIGHTED WITH ASTERISKS AND INCLUDE ADDITIONAL OVERVIEW AND DIAGNOSTIC INFORMATION. HELP USING THE wiTECH DIAGNOSTIC APPLICATION FOR FLASHING AN ECU IS AVAILABLE BY SELECTING “HELP” THEN “HELP CONTENTS” AT THE TOP OF THE wiTECH DIAGNOSTIC APPLICATION WINDOW. THE wiTECH SOFTWARE LEVEL MUST BE AT RELEASE 12.02 OR HIGHER TO PERFORM THIS PROCEDURE. THE DRBIII® FLASH FILES FOR THIS BULLETIN ARE AVAILABLE ON DealerCONNECT. SUBJECT:Flash: Diagnostic Enhancements For Fuel System OVERVIEW:This bulletin provides Engine Control Module (ECM) software enhancements to improve robustness to fuel system issue detection and two new Diagnostic Trouble Codes (DTC's). This bulletin involves selectively erasing and reprogramming the Engine Control Module (ECM) with new software. Diagnostic procedures for these new DTC's are included in this Service Bulletin on the last 2 pages which may be printed. The two new injector Diagnostic Trouble Codes (DTC's) for excessive injector return flow are: P1222 - LEAK DETECTION DURING MOTORING P1223 - LEAK DETECTION BASED ON QUANTITY BALANCE **When the fault(s) occur, a solid Wait to Start lamp will illuminate in the cluster along with chiming 10 times. When the fault goes inactive, it will clear the wait to start lamp with no chimes**. MODELS:2004.5DRRam Truck (2500/3500 Pick Up) 2005 - 2007DHRam Truck (2500 Pick Up) 2006 - 2007D1Ram Truck (3500 Pick Up) NOTE: This bulletin applies to vehicles equipped with a 5.9L Cummins Diesel Engine (sale codes ETC or ETH). PARTS REQUIRED: Qty. Part No. Description 1 04275086AD Label, Authorized Modification REPAIR PROCEDURE 2004.5 - 2005 MY - FLASH USING DRBIII®; - USING THE INTERNET TO RETRIEVE THE FLASH FILE: NOTE: Whenever a controller is programmed, the software in the DRBIII® must be programmed with the latest revision level available. Current software version is 64.1. NOTE: If this flash process is interrupted/aborted, the flash should be restarted. NOTE: Remove any unnecessary PCMCIA cards prior to starting a DRB III® flash. 1. Before beginning the reprogramming procedure, remove any old flash reprogramming files from the DRBIII® memory. To clear the memory from the MAIN MENU power up the DRBIII® and then: a. Simultaneously press the MORE and YES keys. b. A screen will appear requesting a COLD BOOT. c. Follow the on screen instructions by selecting the F4 key. d. When the DRBIIl® reboots to the MAIN MENU, proceed to Step #3. 2. With the ignition switch in the RUN position, determine and record the ECM part number of the ECM currently in the vehicle. Using the DRBIII® select: a. DRBIIl® Standalone b. 1998 - 2007 Diagnostics c. All (Except Below) d. Engine e. Module Display f. Record the ECM part number on the repair order for later reference. NOTE: If the ECM is not operational, the ECM part number can be obtained from the label on the controller. For 2003 and later vehicles, if the label on the controller is not legible, record the Reference Number for use later. The Reference Number is located in the Reference Number box at the top, center of the Engine Data Plate. The Engine Data Plate is located on the intake side of the breather cover or affixed to the APPS bracket. 3. Page back to the Main Menu 4. Determine if the vehicle is equipped with SKIM. Using the DRBIII® select: a. DRBIII® Standalone b. 1998 - 2007 Diagnostics c. All d. System Monitor e. J1850 Module Scan f. Look for “SKIM” in the list of modules 5. If the vehicle is not equipped with SKIM then proceed to Step #6. If the vehicle is equipped with SKIM obtain the vehicle Personal Identification Number (PIN) before continuing with Step #6. This information is available from: a. The original selling invoice. b. The DealerCONNECT system under the Parts tabs - select Key Codes. c. By contacting the District Manager. CAUTION: Failure to install the SKIM pin number into the module after flashing the Cummins ECM will cause a start and stall condition. 6. Install a battery charger and verify that the charging rate provides approximately 13.2 - 13.8 volts. Set the battery charger to continuous charge. Do not allow the charger to time out during the flash process. Remove the charger from the battery when the flash process is complete. NOTE: When reprogramming a Cummins ECM be sure to do the following; • Download the flash file from TechCONNECT to the DRBIII® with the DRBIII® disconnected from the vehicle. • Download the flash file from the DRBIIl® to the vehicle with the DRBIII® disconnected from TechCONNECT. 7. Connect the DRBIII® to TechCONNECT. Open TechTOOLS and verify that the "DRBIII® Status: Connected" message is in the upper right corner of the TechTOOLS screen. 8. Enter the old Cummins ECM part number obtained from the DRBIII® in Step #2 into the Parts Criteria window. 9. Select SHOW UPDATES. 10. Highlight the proper flash file from the list: a. If the old ECM part number is known, highlight the flash file listed, based on the old ECM part number recorded earlier in Step #2. b. If the old part number is not known, highlight the proper flash file based on the Reference No. located in the “Ref. No.” box, at the top, center of the Engine Data Plate. 11. Select the DRBIII® radio button which is next to the DOWNLOAD/UPDATE button. 12. Select the DOWNLOAD/UPDATE button. 13. Monitor the Flash Download/Update Progress window on the TechCONNECT and follow the instructions on TechCONNECT. When the flash process is complete, proceed to the next step. 14. Disconnect the DRBIII® from TechCONNECT. 15. Connect the DRBIII® to the vehicle. 16. Download the flash file from the DRBIIl® to the vehicle. Using the DRBIII® select: a. Vehicle Flash b. Follow the directions on the DRBIII® screen. When the flash process is complete, proceed to the next step. 17. If the vehicle is equipped with SKIM, proceed to Step #18. If the vehicle is not equipped with SKIM, proceed to Step #19. 18. On vehicles equipped with SKIM, transfer the VIN and Security Key information from the SKIM to the ECM. Using the DRBIII® select: a. DRBIII® Standalone b. 1998 - 2007 Diagnostics c. All d. Theft Alarm e. SKIM f. Miscellaneous g. Cummins ECM Replaced h. Follow the directions on the DRBIII® screen. When the process is complete, proceed to Step #20. 19. On vehicles not equipped with SKIM, manually enter the VIN in the ECM. Using the DRBIII® select: a. DRBIII® Standalone b. 1998 - 2007 Diagnostics c. All d. Engine e. Cummins Controller (ECM/ENGINE) f. Miscellaneous g. CM84X Check VIN h. Follow the directions on the DRBIII® screen. When the process is complete, proceed to next step. NOTE: Due to the Cummins controller programming procedure, a DTC may be set in other modules (PCM, TCM, BCM, MIC, SKIM, etc.) within the vehicle, if so equipped. Some DTC's may cause the MIL to illuminate. Check all modules using “Module Scan”, record the DTC's, and erase these DTC's prior to returning the vehicle to the customer. Erase any DTC's in the PCM only after all other modules have had their DTC's erased. NOTE: The following step is required by law. 20. Type the necessary information on the Authorized Modification Label p/n 04275086AB and attach near the VECI label REPAIR PROCEDURE 2006 - 2007 MY - USING WiTECH DIAGNOSTIC APPLICATION: NOTE: HELP USING THE wiTECH DIAGNOSTIC APPLICATION FOR FLASHING AN ECU IS AVAILABLE BY SELECTING “HELP” THEN “HELP CONTENTS” AT THE TOP OF THE wiTECH DIAGNOSTIC APPLICATION WINDOW. NOTE: If this flash process is interrupted/aborted, the flash should be restarted. 1. Reprogram the PCM with the latest software. Follow the detailed service procedures available in DealerCONNECT/TechCONNECT, Refer To Group 8 - Electrical > 8E - Electronic Control Modules - Service Information > Module - Engine Control, Diesel > Standard Procedure > PCM/ECM Reprogramming - Diesel. 2. Type the necessary information on the “Authorized Modification Label” and attach it near the VECI label. Diagnostic procedures for these new DTC's are included in this Service Bulletin on the last 2 pages which may be printed. POLICY: Reimbursable within the provisions of the warranty. TIME ALLOWANCE: Labor Operation No: Description Amount 18-19-04-9G Module, Engine Control (ECM) - Reprogram 2004.5 - 2005 (B) 0.8 Hrs. 18-19-04-9H Module, Engine Control (ECM) - Reprogram 2006 - 2007 (B) 0.4 Hrs.
  3. P1222 - Leak Detection During Motoring NOTE: For a complete wiring diagram, refer to the Wiring Information. When engine is motoring (i.e. Engine is running, but requires no fuel injection) the only required fuel delivery to the rail is due to natural leakage in the system. The natural leakage depends directly on the rail pressure. A definite amount of fuel is required to overcome the natural leakage, for different fuel pressures. The Engine Control Module (ECM) sets Leakage Detected, when the fuel flow exceeds an expected value. When a leak is detected in the system, a counter is initiated. When the counter reaches a predetermined value a fault is set and engine derate is enabled. When the leak is not detected the counter counts down, and once the counter becomes zero the engine is set back to normal running conditions. **A solid Wait to Start lamp will illuminate in the cluster along with chiming 10 times. When the fault goes inactive, it will clear the wait to start lamp with no chimes**. When Monitored: Engine is motoring and at operating temperature with no fuel system and engine speed related DTC's. Set Condition: Counter reaches a calibrated value. Possible CausesEXCESSIVE INJECTOR RETURN NOTE: Always perform the Pre-Diagnostic Troubleshooting procedure before proceeding. OTHER DTC's PRESENT1. Turn the ignition on. 2. With the scan tool, select View DTC's. Are there any other fuel system related DTC's present along with this DTC? a. Yes >>> Perform the diagnostics for the other fuel system DTC's before proceeding. b. No >>>> Perform the INJECTOR RETURN FLOW TEST procedure.
  4. Success!The injector issue is over. I'm currently working on adding the articles to the website and getting error codes and even the TSB article posted up for others. As I went out today on a cold start and turn the key over and waited for the grid heater light and then crank Thor over. Fast and clean start up. Very light blue smoke noticed and settles pre quick after a couple a heating strokes on the burning fuel. P1222 Error code https://mopar1973man.com/cummins/articles.html/3rd-generation/61_engine_61_61/95_obdii-error-codes/p1222-leak-detection-during-motoring-r750/?&do=getNewComment&d=4&id=750 P1223 Error Code https://mopar1973man.com/cummins/articles.html/3rd-generation/61_engine_61_61/95_obdii-error-codes/p1223-leak-detection-based-on-quantity-balance-r749/?&do=getNewComment&d=4&id=749 TSB article https://mopar1973man.com/cummins/articles.html/3rd-generation/tsb-articles/tsb-18-006-12-diagnostic-enhancements-for-fuel-system-r751/?&do=getNewComment&d=4&id=751
  5. No... Please don't do this! Excessive tight valve could cause a stalling issues. The slach is the room it needs when the valve heats and starts to expand. Like myself I was playing with 0.008 and 0.018 for while but the excessive tightness was creating a stalling issue on hot summer days. I don't suggest going tight. Still the spec is still 0.010 intake and 0.020 for exhaust. Might check and measure total lift of each cam lobe and see how much possible wear there could be?
  6. P1223 - Leak Detection Based On Quantity Balance NOTE: For a complete wiring diagram, refer to the Wiring Information. There is a required amount of fuel required by the fuel system to keep the system stable. The amount of fuel required depends on fuel pressure, injection quantity, engine speed, and coolant temperature. The Engine Control Module (ECM) sets Leakage Detected, when the fuel flow exceeds an expected value. When a leak is detected in the system, a counter is initiated. When the counter reaches a predetermined value a fault is set and engine derate is enabled. When the leak is not detected the counter counts down, and once the counter becomes zero the engine is set back to normal running conditions. **A solid Wait to Start lamp will illuminate in the cluster along with chiming 10 times. When the fault goes inactive, it will clear the wait to start lamp with no chimes**. When Monitored:Engine is running above low idle speed and at operating temperature with no fuel system and engine speed related DTC's. • Set Condition: Counter reaches a calibrated value. Always perform the Pre-Diagnostic Troubleshooting procedure before proceeding. Possible CausesExcessive Injector Return NOTE: Always perform the Pre-Diagnostic Troubleshooting procedure before proceeding. OTHER DTC's PRESENT1. Turn the ignition on. 2. With the scan tool, select View DTC's. Are there any other fuel system related DTC's present along with this DTC? a. Yes >>> Perform the diagnostics for the other fuel system DTC's before proceeding. b. No >>>> Perform the INJECTOR RETURN FLOW TEST procedure.
  7. Quadzilla above 204℉ will revert to -40℉. I have installed the transmission temperature sensor in the oil pressure test port. This allows me to adjust timing based on oil temperature. As you find out you can cut up to about 35℉ off the oil temperature vs coolant. I can run as high as 220℉ in coolant but float right around 170-178℉ in oil temperature. Timing can make or break net temperature system-wide. Now that I've retuned around the average 210℉ coolant temperatures you don't need as much timing advancement. Even the picture below I can do this for less than 5 PSI of boost normally.
  8. Yes your correct. More you advance less air needs to be forced into the cylinder also fuel is cut and locked out at lower boost. Currently my best is +30 MPG across state of Washington from Seattle WA to the Idaho border at 300 miles and barely used a 1/4 tank of fuel. Beast is capable of 500 HP. Another tip swap to 200°F thermostat from a 6.7L. More heat, less advancement, better thermal dynamics.
  9. If you wanna increase flow of air all you need to do is retard timing and air flow is increased. Up here cold air is deadly and kills the MPG. Forcing more cold air would require lot more advancement as well. One of the reasons I love BHAF with the 2nd Gens
  10. Remember there is a very wide allowance. Like exhaust is 0.015 to 0.030 or intake is 0.006 to 0.015 are conidered normal.
  11. Food for thought. When tuning for efficiency like myself less boost is better. More boost pressure more you are unlocking fuel to flow. This will in turn create lower EGTs and cooler running engine. Even with Beast at 500 HP it cruise at 82 MPH in 5th gear at mere 2,500 RPMs but keep boost below 10 PSI and EGTs at 700°F. At slower 65 MPH I'm right at 2,000 RPM but EGTs drop to 550°F and boost of barely 1 to 2 PSI.
  12. ISSPro EV2. The ISSPro EV3 is bluetooth programmable and even more options.
  13. Dang! Your body work / metal work is highly Impressive! To keep the repair area as a minimum and even get the roll correct. Nice job! I should get you out here to wave your magic wand on my body work for Beast.
  14. Low pressure light - ISSPro EV2 programmable Fuel Pressure gauge.
  15. We have a W or Win today. The injectors came back from @dieselautopower and were test out as a set again. I'll post up the flow rate report when I get back to the shop to grab the paper, which is a bit torn up. I'll post the flow rates. I install exactly to spec on everything for torque and process. Fired up smoked a bit of white, but very shortly cleared up and ran smooth. Yup, Diesel Auto Power did find 2 injectors with issues and been repaired again. Mark and I got the tail lights rigged up on the tail of the frame and my license plate. I took off to town for a bit of joy ride. Thor ran great. Idle is exactly 800 RPM and the fuel rail pressure settles at about 800 PSI swing from open to close with injectors. No grid heater light. No dinging bell. Easy start and been consistent. My trip to town I visited two friends with Thor and then stopped by the grocery store for a jug of milk. Each stop very easy starting and no smoke at all. Now with the bed and that huge front bumper off this truck is quick. It can climb to 80 MPH very easy without the extra 2,800 pounds of steel flat bed and bumper off. Even the Fuel Mileage rose today for the first time being its on it way up towards high 16 MPH which it never done much better than 13 to 14 MPG. Yes the over sized injectors foul the trip the computer so its off by about -2 MPG roughly.
  16. Sorry but that appears to be modified. I would look at another Dodge in possibly a wrecking yard or in a parking lot. Just some of the parts look wrong or welded. @IBMobile i know has a Auto and maybe get a photo of your linkage sir?
  17. This is not exactly true. It the fact the Cummins released all ECM control to Mopar / FCA. Your dealers are only focused on sending people to their dealer. What about myself a mechanic looking for technical information about repairing say vehicle? Nope! This is the part that is screwed up is the fact I'm a LLC business and hired by my client or my own vehicle in my shop I should not be forced into the dealer. I did learn that Feb 2012 there was a update to Thor's firmware at some point in the past that added the grid heater light and error codes to the ECM. If you are looking for the error codes in the 2006 FSM it will not exist being that information was released in Feb. 2012.
  18. Super cool looking wood for the floor of the bed. That's going to be a sweet looking ride? Any paint information available yet? Photos?
  19. Interresting... I didn't really pay attention to that detail.
  20. Look over on the CCD network article and test the CCD+ CCD- pins to ground. After the computers stop talking it should be 2.49 and 2.51 volts.
  21. Sounds like a winner for the W-T ground wire mod.
  22. Only had one output speed sensor to replace in 22 years of doing this. Rare but yeah does happen.
  23. All I can say is don't call either Cummins or Dodge dealers because they will not help you. They will request the truck be brought to their shop for repair even though you tell them your already a diesel repair shop and just need information. Cummins Care - (800) 286-6467 Dodge Corporate - (800) 334-9200 Remember ECM stuff is all Dodge corporate and will not get any information for and Cummins electronics.
  24. Oh ill find it for sure. I've got the gift of gab. I can always talk to some one and get it.
  25. Now I've got a 4G LTE cell tower here at my place. Its barely a 0.1 Watt extender but the signal reaches out the office area quite well. Internet Provided by Starlink / Space X Cell service provided by Verizon Network Provided by TP-Link (ER605 Gateway and SG2428 Managed Switch) WiFi Provided by TP-Link (EAP225) Shared Network Printer (MF4150 Cannon Laser Printer) Ubuntu 24.04 Linux Operation System 1 TB Hard drive for storage Picture below of the new Verizon Extender and its now fired up and providing 4G LTE service across my property. Then had to share my server cabinet. It's slowly coming together now. Now have a network shared printer off my server that all of us can access and use from any device including printing documents from a cellphone too.
