Everything posted by cajflynn
Pics of me towing things
I like how he acts like he didn't know what I was saying. Maybe it's better we don't know the whole story.
Your story.
There has to be more to this story.
Roadtrip Adventure spare parts list!
Take your AAA card that has the 200 mile free tow on it. Best tool I own.
Someone needs to straighten these people out
http://www.thehulltruth.com/trucks-trailers/506255-diesel-fuel-additives.html
Heater Core Questions
evaporator
Should I 6.7????
What are you going to get?
Will Catalytic Converter Get Rid of Drone?
The cat does not impede performance in the 5.9 third gen so put it back in. I think it will stop the drone.
Let me see if I understand what you are saying: Your problem is you can't hear your wife when you're driving? I'd like to install whatever you have in my truck!
Should I 6.7????
Or time to put more diesel in your truck...
It took me and a friend less than 3 hours to change the heater core. You should change the evaporator while you're in there.
- Hey, boat guys...
No Codes but will surge a little on steady hwy speeds or up hills Please Help!!!
You may not have any codes because the problem isn't bad enough to set one yet. I'm not saying I know if it is the vp44. I'm just thinking it sounds like it could be. I would really exhaust all other avenues first.
Hey, boat guys...
Looks like they are doing work on the engine. That one is probably not connected. - - - Updated - - - Looks like they are doing work on the engine. That one is probably not connected.
Hey, boat guys...
You don't want the flames hitting that paint job.
Yes it is the same wire you used to set the timbo apps. I don't know of anyway to test the vp44. Pretty much if you can't find anything else wrong then it's probably to vp44. It sounds like the vp44 to me.
Hey, boat guys...
Cam sensor. My tach has always jittered. No idea how to fix it.
As you are driving. You may have to tape the vm to windshield or something. If it fluctuates then maybe the APPS is bad. If not, maybe the vp44. - - - Updated - - - People that have a scan gauge can see the values for the tps on their gauge. The values will go up as you press the pedal. So if the truck surges and there is no corresponding increase on the tps values then the apps is not causing the surge.
Hey, boat guys...
Kelly? Tell us more.
New to this forum need some advise
Probably. It would be hard to guess what kind of miles were on the tranny already. I run the smarty jr on tow mode in my trucks that pull that kind of weight. HUGE difference. You will really like it.
update on vp install... wierd noises now apparent.
How about the intake gasket? A pshh sound to me would either be air of fuel. The fact that it isn't constant make it sound more like fuel. If it was a head gasket I would expect to see coolant. - - - Updated - - - How about the intake gasket? A pshh sound to me would either be air of fuel. The fact that it isn't constant make it sound more like fuel. If it was a head gasket I would expect to see coolant.
You can try hooking up the voltmeter to the APPS and watch it to see if the values change when you are surging or not. You might also call Tim (of Timbo apps) and ask him what he thinks.
Dana 70 pinion seal replace
I always used an impact too.
Dead on the highway
I was asking how to bleed it in case I ran out of fuel. I think the pump looks pretty cool. Raptor customer service is terrible and makes me wish this mechanical pump existed a few years ago.
