scummins
Everything posted by scummins
  1. I recently ran a 350 mile trip. My average speed was about 55 mph and i got about 20.4 mpg. This is from the overhead console i didnt hand calculate it out. But i notice that your rpms are much lower than mine i rev about 2000 at 55. why such a difference?
  2. I spent some time looking for joint connector 3 this weekend but i had no luck finding it. I started on the right side bumper, check underneath near the frame and then behind the front right headlight even took off the battery rest. I could find anything, i then moved to the other side looked underneath by the fram and followed the wires up and saw no such connector...this one really has me stumped.
  3. Here are a few pics of the texture up close
  4. All Done! It was really simple took only 2 hours of prep and about 3-4 hours painting for 2 coats and an hour in between coats. I think the prep is really important i was told before i started that you actually do not want to go down to bare metal if you don't have to. Hurculiner is an epoxy paint and i was told it creates a stronger bond on top of the factory paint. Which also means dont primer before you put the Hurculiner on it will compromise its bond. Here are the steps that i took.Supplies needed:- broom/vacumm- paint tray- rag- acetone- gloves- paint roller- paint brush 2in- masking tape- sandpaper 180 grit- scuff pad1) I swept, vacuumed, washed the truck and the bed to have a clean surface2) mask off all the areas that you dont want to sand or paint3) sand all areas that are going to be painted. If you buy the kit it comes with a scuff pad. I found that it takes a long time with the scuff pad because of its fine grit. So i started with 180 grit sandpaper to rough up the surface and then finished with the scuff pad because it helps to remove some of the sanding dust off the surface.4) Then i wiped down all the surfaces with acetone to remove the remaining surface dust to ensure a good bond5) I mixed the Hurculiner with a power drill attachment to make sure that the grit was properly emulsified in the paint6) poored a small amount into a paint tray to that the grit didnt settle while painting7) started with corners with a paint brush and brought it out from there about 1.5 in 8) after the corners were done i got the rest with the roller making sure not to apply it too thick9) waited an hour and then did a second coat10) after 2nd coat was applied immediately removed painters tape so the dried hurculiner wouldnt make it tearI only used about half a gallon to do rockers, top of bed sides, and the back face of the bed.
  5. I started the prep work for my truck. i am going to use hurculiner on the bed and the rocker panels. I will post picks and any suggestions that i have once done with the process. i may eventuallymake my own stencils and create a duck camo finish on it.
  6. yea it seems pretty crazy that i can get a whole turbo back kit for marginally more. I will have to check the integrity of the rest of the exhaust and see if it makes economical sense. hate to spend money i dont need to.
  7. The truck i just recently purchased is missing the rear end of the tail pipe, about the last 16-20 inches or so. I am wonder where i can get cheap piping and or a cheap exhaust tip? Anyone have any good suggestions?
  8. Thank for the update. That must be correct i am going to have to dig a little further and see if i can find that connection. Hopefully i can i will keep you updated!
  9. so in doing a little investigating i think that i found g100 and it appears to be a solid ground. i hooked up the light tester to the positive terminal of the battery and probed at the 4wd drive switch (both leads good), i then probed after the first connection (both leads good), and finally i probed the ground connection g100 and that also seemed to be good. but when i probed the wire at the abs control module and the wire behind the dash, i have no ground so i must loose it somewhere between the switch and then abs and instrument cluster but i cant seem to trace it back to that connection.
  10. yea i had the same thought...unfortunately. Ground issues are a bear to trace out!
  11. Yea sorry I really appreciate the help though! I will keep digging and if I find anything I will keep this thread updated.
  12. yea i did see that but the only issue is, is that i traced the wires to the drivers side not passenger side so that info must not be correct for my truck.
  13. I did some more digging yesterday trying to find the mysterious joint connector number 3...maybe i have the wrong name for the connection i am looking for but i traced the wire (from the 4wd switch) as far as i could follow it (which wasn't very far) and it goes up toward the right wheel well. The connection im trying to find is in the diagram in the following link... http://articles.mopar1973man.com/images/2ndgen24v/antilock-brake-system/4w-abs-2.jpg Im not sure if this is a plastic connector or if it is just a splice or what but it looks to have at least 7 wires to it from the diagram. Any ideas? Sam
  14. Thanks for the replies and the help i think i have it all sorted out now. It looks like i had a bad ground when i was doing my original testing once i verified that i had a good grounding point the connector checked out. I also figured out why they didn't use the original wire harness connector. After i got my ground verified i checked out the factory connector to see if it was useable and after a little cleaning i saw that the terminals were very badly corroded so that must have been why they used the aftermarket version. Once again thanks!
  15. http://youtu.be/n7Ftcg1pqwc
  16. I think you may have something else other than the safety switch going on. The reason i say this is that the safety switch on the tranny will not let the engine crank unless it is in park or neutral. I would start by verifying that you have fuel and spark and then go from there.
  17. Are you loosing coolant? blown head gaskets often show signs of over heating.
  18. yea if i could find where the other end of that harness goes to i could trace it back to each point and figure out where my break is. it must be an open circuit because like i said i have no blown fuses.
  19. yea i have nothing at the factory plug
  20. well i have something funky going on i think... it looks like it does in fact have the connector for the factor harness but, looks like someone has installed a spliced trailer plug.
  21. For 30 some odd dollars i think buying a new connector is the easiest option, but while looking at them online how do i know whether or not i have the factory 7 pin connector? I see that with the factory 7 pin connector i can get the plug and play model but if i don't have the factory set up than i have to get the splice kit. How can i identify what i have?
  22. Im still having problems locating this connection does anyone happen to have pictures?
  23. There are two reasons why i might rule this out in my case. 1. I would think if there is a short in the trailer connector that i would have a blown fuse and i don't.2. I used a light tester and actually probed in the wires just behind the physical connector.where to the wire connect to blinks and flashers? how far back can i trace them to figure out my failure point?Thanks
  24. I just noticed today on my way to work that when you use the power window control the 4wd light gets brighter. Any ideas?
  25. I went to test my 7 pin trailer connector the other day and i only have power and the electric brakes and the constant 12V. The 12V also goes on with the brakes, which i assume it should always have power. Where can i trace the wires back to? is there a common failure point? http://forum.mopar1973man.com/image/gif;base64,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
