scummins
Everything posted by scummins
  1. Hey guys if anyone is willing to give up a little time in there day. Follow this link and vote for Bruce Carnahan for the stormy kromer living legend! http://www.stormykromer.com/living-legend-2014/ Sent from my RM-820_nam_att_100 using Tapatalk
  2. Alright u all have given me the confidence boost I needed. Gona check this off the list this weekend! Lol :-)Sent from my RM-820_nam_att_100 using Tapatalk
  3. I cant get myself to drill in my exhaust manifold either I've had the thermocouple sitting on my desk since July! Did u take ur turbo off? Any tips?Sent from my RM-820_nam_att_100 using Tapatalk
  4. Look at getting Laramie seats they have adjustable lumbar supportsSent from my RM-820_nam_att_100 using Tapatalk
  5. I think all opinions are helpful after that is probably why most of this joined and post on this site, to get a different perspective on things we do or want to do with our trucks. The one thing I noticed on my truck that the fender flares may or may not fix is when its wet I get tire spray all around my wheel well. At certain speeds it actually gets shot straight up. But I agree rocks and dirt the flares are probably not much of a remedy.Sent from my RM-820_nam_att_100 using Tapatalk
  6. Diesel4life yea that rubber strip along the top is wat im referring to. So the adhesive like u said must be a new addition. In that case I will skip that part and just screw them on. Thanks for the help!Sent from my RM-820_nam_att_100 using Tapatalk
  7. Yea they are the same as yours diesel4life and screw on to the inner wheel well also but I looked the install instructions and they say that the rubber strip along the edge adheres to the side of the fender. But maybe this is an unnecessary step. Sent from my RM-820_nam_att_100 using Tapatalk
  8. It depends both body styles were made in 2002. But if u have the 2nd Gen body style, 94-2002, then yes 2001 and 02 are identical. But pictured is obviously a 3rd Gen.Sent from my RM-820_nam_att_100 using Tapatalk
  9. Hi guys a guy sold me a used set of fender flares. I am looking at putting them on my truck, originally the kit comes with a rubber trim piece that has adhesive that sticks to the truck and then goes over the edge of the plastic fender flare to protect the truck. Since these are used the adhesive is long gone but I have the rubber stops still. So my question is are they any suggestion on a kind of double sided tape or anything to attach the strips to the truck.Sent from my RM-820_nam_att_100 using Tapatalk
  10. Grainier also has a good selection both crimp able and clamp type Sent from my iPad using Tapatalk
  11. Ahhhhhhh yea sorry I misread. Yes that gauge would mean its a twisted group of 5-0 gauge and 3-0 gauge wires respectively. So that makes sense then. Sent from my iPad using Tapatalk
  12. I would assume that the wire to the starter should be larger than the negative and crossover cables. So to me I don't know if I would trust those numbers. That's just my intuition though. I will see if I can find the actual gauge sizes.Sent from my RM-820_nam_att_100 using Tapatalk
  13. So the tires have made it much better but it happened once the other day so I will follow up once I test the steering components update: I have found some info on genos garage for anyone else dealing with this problem. Follow this link and there is some info at the top of the page along with a few more links. http://www.genosgarage.com/Steering-and-Suspension/departments/140/ Sent from my RM-820_nam_att_100 using Tapatalk
  14. I had load range D tires that were very worn out, I just replaced them on wed and haven't had any issues since we will see if this fixes it permanently or just a temporary fix. Sent from my RM-820_nam_att_100 using Tapatalk
  15. I just put on a set of primewell h/t 265/75R16 from tires plus after taking everyones advice and got rid of the old 16.50in rims. i am very happy so far. we will see when winter sets in how they preform but so far they are great. they were on the cheap 580 out the door, with lifetime rotation and a prorated warranty.
  16. okay that's great to hear I will start researching rims and tires. I thought I would end up spending more by switching but if I can do it and spend less money that's great!Sent from my RM-820_nam_att_100 using Tapatalk
  17. sorry i cant seem to find them on there website. where are you looking?
  18. Does anyone know if any other tire company besides BF Goodrich makes a tire in 33x12.50-R16.5?
  19. Yes the videos in that thread are a perfect example of what is happening to me! Thanks for the info! which component is most likely at fault? or does it differ greatly?
  20. Hi Guys,This started about a week ago i was driving downt he road when i hit a significant bump. Immediately my truck started to shake, up and down, like it was bouncing down the road. I can to a stop and check out everything, i didnt see anything out of the ordinary so i went on my way. When i started rolling again the shake was gone. The episodes have been becoming more frequent it happened 2 today in a 10 mile drive. Has anyone one see this or ran into this? i took it to the shop today and they told me everything seemed tight. But i know something is seriously wrong.
  21. I would look at the timing unit itself. Might have to do some digging to find out what controls it but usually for electronic timing its controlled by a circuit consisting of resistors and capacitors. Could be a bad circuit component or loose wiring.Sent from my RM-820_nam_att_100 using Tapatalk
  22. There is no problem running a jumper for the egt probe wires, you could also run your own wire the whole way if you would like. The resistance of typical wire is so similar if not exact that it will not mess with the thermocouple reading. The thermocouple works by having two very different materials that have different properties at different temperatures and the gauge reading comes from the voltage drop across these two different materials. A lead wire from the gauge to thermocouple is not going to affect this reading significantly. But I would remind you never to mix stranded and solid wires in a wire nut and would recommend only using standard wire for vehicle applications. I would also use higher quality wire aka not speaker wire, its not made to carry significant load or hold up under car conditions.Sent from my RM-820_nam_att_100 using Tapatalk
  23. I have 4.10 gears and I start in 2nd even with a 6 x 12 single axle trailer in tow. Unless im on an incline, but otherwise np.Sent from my RM-820_nam_att_100 using Tapatalk
  24. yea nice spot! that isnt my truck i didnt have a camera so i just used trusty old google to get me a pick of the same dash layout as mine!
