TFaoro
Everything posted by TFaoro
  1. TFaoro posted an Cummins article in Engine
    Hang in there as i am working on building this Article. Firstly, have all your parts cleaned and prepped, identified and ready to fully assemble. Seals, front and rear mains. Drive your seals in with the tools provided in the cummins kits. the rear is easier and the open end goes towards front. The front main is a PITA but once you get it driven as far as the tool will let you it will hold. Leave the install sleaves in them, if you have to remove them pull them out and to replace them just kinda fold them onto itself then put it inside the seal to install. Driving the seal in from the rear of the seal housing. Hammer it down in small increments Drive the seal in until the tool bottoms out evenly along the rim. how it will look on the backside next is piston assembly. I didnt get pics of the assembly but its easy. Assemble each piston fully one at a time with rod, wrist pins/c-clips, rings. the rings go in order of installation (bottom to top of piston) 1. oil ring (3 piece) lower flat ring then oil waffle ring then upper flat ring (stagger gap 120 deg) 2. scraper ring FOLLOW PRODUCT ORIENTATION there will be a marking or dot showing UP. Use ring installer and open ring enough to place into groove without scraping piston. 3, compression ring (see info above) Also prep the crank and ensure it is PERFECTLY clean ZERO debris on journals. Next is block prep. Install 6 oil cooler jets with a punch gently tapped into place to hold them. ensure they are free of debris. Then with a air hose blow the seats of the upper main bearings clean and the back of the upper main bearing then place down immediately to ensure no dust gets between the surfaces. Repeat for all mains and ensure proper orientation. Thrust bearing goes on #6 main journal seat. Inspect to make sure ALL jets are in place and all bearings are clean with a spray of air. liberal use of assembly lube of your choice is to be placed on bearing faces and smeared around to get it on the whole bearing. Setting the crank Blow out all the passages of the oil galleys in the crank and blow the crank journals clean. With TWO people GENTLY lay the crank into the mains EVENLY and apply more lube on the journals. (i used cat 5 cable as a harness to hold the crank on a journal as i lowered it in, worked well) Spin the crank just enough to ensure proper seating into the bearings and visually inspect that is is seated in all bearings. Bearing cap install with each clean cap, blow clean to ensure no dust is present, also on back of lower main bearing, mate the two together. Lube with assembly lube and place on block in proper orientation. Put the same cap on where it came off of. Using machine oil on the threads and hand thread them in. (torque later) Repeat for all bearing main caps. once all caps/bearings are placed, torque to spec in the pattern required. (will get specs and pattern later) Piston install/rod cap install prelube each bore with machine oil to ensure no scraping and ease of installment two people make this work better. with assembled piston place the ring compressor over all rings just past the oil rings and gently insert into bore with proper orientation until the ring compressor sits against the deck. then with a hammer, place the handle on the center of the crown and hold pressure against the piston while tapping it with your hand to push it into the bore until the ring compressor comes off STOP HERE. place a rod bearing on the rod then lube well and have your friend hold the end of the rod and guide it onto the crank as you push the piston in with the hammer handle in small increments until it seats. Rod cap install place lower rod bearing onto cap and lube well then place onto crank in proper orientation and hand tighten. Repeat piston install and rod cap install for each piston. Then torque to 74ft/lb in 3 steps (will get info later) front gear housing install i placed gasket shellac on the housing surface then place the gasket on then coated with shellac and mated to the block. All bolts are torqued 18ft/lb and blue loctight now is a good time to inspect the killer dowel pin issue. My cover didnt need it. cam install/thrust plate install lube cam very well and without scoring the cam bearing insert cam into block and mate the cam to the crank via the markings you see above. crank has one dot cam has two dots for this mate. thrust plate install with cam installed and aligned, slide thrust plate in behind cam (pull cam out slightly) then place both bolts in with blue loctight and torque to 18ft/lb oil pump install place oil pump onto block face and hand tighten all 4 bolts with blue loctight then in criss cross pattern torque to 18ft/lb injection pump gear install as well with timing mark on the cam as seen below. gear housing cover install with shellac on the gasket surface place gasket on cover then coat with more shellac. place the cover over the front main of the crank and align then push the install sleeve onto the crank, then push the cover onto the crank. the sleeve will fall off, start bolting to 18ft/lb and blue loctight. rear main seal install shellac the surface of the housing then place gasket and shellac more, align and push install sleeve onto crank, then push the cover over the crank and the sleeve will fall off. torque i think is 18ft/lb (take block off stand to do this then put back on stand afterwards) water pump and fan pulley install blue loctight all bolts to 18ft/lb ensure surfaces are clean for water pump rubber oring (square oring) install fan serpentine pulley onto mount. blue loctight oil pickup tube install with shellac on both sides of gasket or not, torque to 18ft/lb and blue locktight oil pan install shave rear main gasket with razor blade smooth to the block along with the front housing gasket. shellac the surface of the block then place oil pan gasket and shellac more. place oil pan down and torque all bolts with blue loctight to 18ft/lb oil cooler and water outlet /ac compressor bracket install using the proper gaskets for the oil cooler DO NOT SHELLAC, bolt the oil cooler to the block and torque to 18ft/lb and blue loctigt, then bolt the water outlet/compressor bracket to 32ft/lb i think and blue loctight. pushrod side cover place rubber gasket with proper orientation (tab should be facing out and pointing forward) then bolt down to 18ft/lb and blue loctight vacuum pump install bolt bracket to block and torque then set pump into housing and bolt down tight to housing. install oil feed line and tighten bracket and oil line install oil pressure sensor install cam position sensor install block oil hole cover thingy. use shellac then tighten install OEM lift pump bracket (or block off plate) with gasket and shellac, torque 18ft/lb head gasket i coated my headgasket with permatex copper spray then set down on the deck and aligned.inspect to ensure no forign debris is in pistons. (blow out with air before putting down gasket) laying the head down again, visually inspect no debris is in the pistons. with two people in one shot gently lay head down and align with guide dowels bolting the head down/valve train install and adjustment with machine oil lube the threads and hand thread to stop for all bolts. torque in sequence in 3 steps (will get info later) then once fully torqued and rechecked, install the pushrods and rocker assemblies. loosen the rocker adjuster screws all out then torque assemblies down (will get ft/lb later) recheck torque. do a valve adjustment when you like. install MAP sensor (the left one) and intake air temp sensor (right) on the driver side rear of head install lift brackets, thermostat housing torque 18ft/lb, instake cover with shellac on the gasket and torque to 18ft/lb and blue loctight and paint. install transmission adapter and flywheel-clutch/torque converter. (will get specs later) use alightnment tool for clutch. make sure to grease up the pilot bearing. torque the pressure plate down in small increments each bolt to 18ft/lb flywheel i think it 92ft/lb and blue loctight you can install the injection pump now if you wish or in the truck. install in truck!
  2. Getting close. Will be finished up today.
  3. If it's fully deleted go ahead and run 2 stroke. If it's not I wouldn't want to risk plugging emissions equipment. Like Mike said, if your fuel is questionable run the white bottle power service. Other than that I wouldn't worry.
  4. I'd like to be done messing with the motor for a bit so maybe this'll keep my mitts out of there. I replaced the valve cover gasket last night in hope that would stop the leak off the back side. I didn't use the new one when I rebuilt it so I had a spare one laying around. It was starting to run off and drip off of the bell housing. I've still got to re-route the coolant line to the passenger side heater core hose. I would love pictures but I'm not sure if anyone here has twins on a 2nd gen. The vibration is gone with the balanced driveshaft. It's nice and smooth now all the way up to some high speeds. The dang thing is still trying to death wobble though. That's getting old and I can't find what's wrong. Went to start it this morning and the batteries are shot. Only made a half a turn before stopping. I knew they were getting bad after being drained to dead a couple times. If it's not one thing it's another.... Still waiting on the light bar to show up so that I can weld in the last two brackets. I love USPS in rural areas
  5. Too late haha she's welded in solid. If I need to work on it I can pull the bumper. It's not hard and isn't that heavy. I had my driveshaft balanced yesterday. Hopefully this fixes the vibrating. They put a pretty big weight on the yoke end and a small one on the pinion end
  6. All in good time. It's made by Move. I cut their company logo out of the middle... Airflow is more important to me. All in good time. $650 without any lights. You better have a pretty big brake.... Lots of progress.... I final welded all of the sections together and ground the front smooth. There are full beads on every section front and back. I made sure to do an inch or so at a time to prevent warping. That took forever..... I used some very thick expanded metal to keep large debris out of the "vent" in the middle. It's held in place by bolts, and I'll probably throw some pieces of strap on the bolts to keep it from vibrating. I wanted to make it removable just in case I decide to change it someday. URL=http://s103.photobucket.com/user/TFaoro/media/IMG_20151226_175736074_zps41zfzezt.jpg.html] I then welded in the bottom plate for the light bar. This makes it so you can't see down into the condenser and frame mounts. Came out pretty slick IMO. Then onto the fog lights. Those were 2 piece mounts that were welded together then to the bumper, making everything smooth in the front of course. I then mounted it up to the truck for side bracing and grille guard. Tacked the bar on to get measurements for cutting. It's sitting way too high in these pictures. Here's the bar cut to to math the curvature of the bumper and down a bit. I took off about 2 inches. It's welded right on top of the frame mount braces, so it should b e plenty strong. I then worked on the side braces. I was able to use the stock braces and just weld a stud to outside part of the bumper. You can also see the LED mounts in these pictures. Last couple pictures. I just have to weld in the light bar mount, finish welding the grill guard, and do some final cleaning. It'll then be sent to my paint guy for priming, then Rhino lining. Note the bar looks smaller when the truck is on the ground and not at head height.
  7. White bottle of power service and 2 stroke during the winters. Only way I can keep it from gelling here. Reply merged from double post.
  8. I just got told to go to the shop and start welding. Works for me! We'll have a late lunch today.... most of the family had to work this morning.
  9. Not impressed with diamond eye mufflers. My dad and brother both had to add a second muffler to reduce the drone in the cab. One is a 12v, one is a CR. I was going to buy an FTE, but the second turbo killed every bit of drone I had and reduced outside noise considerably. I can't hear my exhaust while driving with the windows down..... whether that's because the primary screams so loud I can't hear it or it's that quiet I'm not sure.
  10. 72" lift? Those of you who read this today Merry Christmas!! Made a bunch of progress on the bumper. Started out by bolting up the frame mounts and making them level with the frame. Also pushed them down to the bottom of their adjustment. Next was mounting up the center section. I was by myself this morning, so I used a cherry picker to help hold it in place. I then tacked it up. I later found out I had the frame mounts on the wrong sides and had to cut the front off and start over. Bad instructions.... O well. Here's a couple tacked up pictures. The red clamp was there to make sure our distances were the same. We then pulled it off the lift so my dad could work on putting some lights up. You can see in the previous pictures the mount to the front plate doesn't support very much. I didn't like it, so I made a cardboard template to brace the top parts of the bumper. Cut some plate to match.... Welded everything solid. I made sure to move around a lot and not focus on a single bead while welding. This seemed to work really well with minimizing heat distortion. Sorry my potato phone sucks! We then bolted it back to the truck and started fitting up the sides and ends. That was fun making everything match.... I think it matches up really nicely though. You can see the top is not even in the last picture, but that was pulled up with a clamp and is now nice and smooth. I've got the entire outside now welded and will finish the inside tomorrow while also grinding everything smooth. Then it's on to light mounts! (The jacket was there to lay over the fenders and headlights while tacking) Thoughts? Comments? Questions?
  11. Made a little progress tonight. Got the old bumper pulled and some cutting done on the new one. I will say the new lift sure comes in handy! This is my dad standing under the truck and he's right at 6ft tall. Still had another 6in or so left in the lift too.
  12. BUT Just because it's closed doesn't mean the engine will not continue to cool, thus my heater blasted comment that was ignored.
  13. What point are you trying to make with this? Do you really think the hx won't hold up or what? It's a tried and true setup....
  14. Do you have the heater cranked? You'd be surprised how much heat the heater sucks out of the engine.
  15. Come on.... What was loose under there. Can't be giving partial info like that!
  16. Having a monster gooseneck is awesome, but it becomes a pita when you want to pick up something small that doesn't fit in the bed of a truck.
  17. That's why Cowboy said this
  18. Very nice! Fenders get crushed way too easy, and those will easily stand the test of time. Little thicker than I would have gone but sometime you gotta use what you have! BTW those welds
  19. Tone rings all look good? I know this is a wild guess, but at this point??
  20. From what I read they take forever to get anything done.... Quality products with horrible wait times. With longer arms you'd think it would ride more like a 3rd gen up front. Mine is horrible compared to my brother's 05. Like night and day difference. We both have 2" leveling spacers up front too. You'd think with longer arms and better springs it should ride significantly better. I'd really like to do the shackle flip IF it helps like they say it does. I know it would help eliminate axle wrap too. Traction bars do their job, but they make it ride even worse in the rear. I'm considering building a set of ladder bars this summer. At least then it wouldn't be quite as bad.
  21. From the picture I posted, the bracket is still there?? Would you mind posting pictures of your setup? I bet I could build almost everything and save a lot of money.
  22. Got a 2 post lift put in for my dad this weekend.... that'll be nice to work on the truck. Bumper is supposed to show up today, so I'll have to get on that asap. I'll try and take pictures if anyone is interested in a writeup. I plan on tacking it all together on the truck, then pulling it off and doing the finish welding. From there I'll prime it with an epoxy primer then shoot it with the same rhino lining that's on my rocker panels. I haven't had a chance to get under it and find out what's going on with the trans mount. Hoping to pull the driveshaft and get it balanced as well. So much to do and so little time.
  23. Definitely understand that!! BUT I bet you could buy just the two top arms from them and build the rest yourself. I'm just throwing ideas out because I'm considering it myself haha! http://www.dodgeoffroad.com/store_DORlongarms.php
  24. Have you looked at dodge off road's long arm kit? They basically went around the stock mount instead of cutting it off. This style would probably provide you with the best ride quality in the front.
