New A/C Compressor squeaking
Agree with @Max Tuneabout either of the valves leaking, especially the high pressure valve. Spray with soapy water to detect a leak and then blow the fitting dry with compressed air before installing the protective cap. Rapid compressor cycling strongly suggests a refrigerant leak. When you get back to the truck, don't forget to test the serpentine belt noise with WD40. - John
Fat tire e bike and bike rack 48 inches from the hitch...
My concern would not be the hitch rating. It would be the unweighting of the front axle. Your modified load may be 4 feet behind the hitch, but it is closer to 7 feet behind the rear axle. The rear axle is the fulcrum. This is why weighing the truck before and after the modification is important. Need to ensure that the proper weight is on the front axle. - John
I have a feeling that he has considered that option, but doesn't want the bike mounted there. - John
@JAG1, if you haven't done so already, I would independently weigh the front axle and rear axle of your truck empty. Record the weights and keep them somewhere accessible. Then load your camper and gear and weigh the truck again. Do this before you make any modifications to the rear of the truck / camper. If the front axle is too light / heavy, then redistribute your gear to get the front axle weight where it should be. If / when you make your modification, then re-weigh the truck with the camper and gear loaded. Figure out where to place gear to get the proper amount of weight back onto the front axle. Years ago, I used to own a slide-in truck camper. It weighed approximately 3,500 lbs with water, propane, and gear. My truck empty with driver and tonneau cover: FA - 4,400 lbs RA - 3,050 lbs 7,450 lbs total Truck with slide-in camper, water, propane, gear, and two people: FA - 4,850 lbs RA - 6,150 lbs 11,000 lbs total What was important to me was ensuring that I gained some weight on the front axle when the camper and gear were loaded. In my case the front axle gained 450 lbs. The gross weight rating for the front axle is 5,200 lbs. The 4,850 lbs on the front axle worked well for me and fell in about mid-way between the empty weight and the gross weight rating of the axle. Weighing the truck before and after is the only way to know how the weight is distributed on the axles. This is especially important to know for high center of gravity loads. - John
Not sure of the belt brand, but I did buy it from Geno's in October of 2014. That belt has currently logged about 165,000 miles. Just inspected it and all of the pulleys about three days ago. All in good condition and the belt is still quiet. - John
This condition indicates to me that the problem is not the compressor. There are two different bearings sets involved with the compressor / clutch assembly. When the compressor clutch is disengaged, the only bearing that is rotating is the clutch to input shaft bearing. When the compressor clutch is engaged the clutch to input shaft bearing stops rotating and the front bearing inside the compressor begins rotating. If one of these bearing is faulty, then the noise should disappear either when the compressor is engaged or disengaged. It sounds to me that the noise is coming from another component or the belt. The noise pitch changes when the AC compressor cycles on and off because the belt load is changed. Since the noise is also occurring at idle, I would spray some WD-40 onto the belt (carefully) while the engine is running. If the noise does not change significantly or go completely away, then I would think the belt is not the problem, but a belt driven component is the problem. In my experience over the years, belts can make horrendous noises that would make you look elsewhere, especially if any coolant has dripped onto the belt. I also think that it is worth removing the belt and try rotating and moving every pulley side-to-side and forward / backward to observe anything out of the ordinary. - John
More questions than answers. Is the noise EXACTLY the same as before? How far is the drive home? 2 miles..., 30 miles? Did the noise occur right away? What are the engine rpms when the noise occurs? Does the noise still occur when the AC compressor is not running? When you had the serpentine belt removed, did you check the condition of the other pulleys? How about the belt condition? These details are needed to help eliminate possible sources of the noise. - John
code 2509 2127
P2509 ECM/PCM Power Input Signal Intermittent P2127 Pedal Validation Switch 2 Low I would stop changing parts. You may have good intentions, but new problems could easily be introduced and make it even more difficult to diagnose. I would start with P2509 code. If power to the ECM/PCM is intermittent (not sure if there is a PCM on a 2003), this could easily be the source of your problem. You have access to wiring diagrams on this site, if you don't have a factory service manual. The ECM/PCM power source needs to confirmed that it is in good working order. Double check that all positive and negative wires were reconnected when you installed the new batteries. - John
AC drain issues
Here's another tidbit of information. As has been noted, there is just a piece of straight pipe sticking out into the engine compartment. A few years ago my passenger side carpet was getting wet. Turned out that the seal between the HVAC housing and engine firewall had weathered enough to allow water leaving the end of the pipe to find a path back into the cabin. I inserted a rubber hose elbow on the end pipe - problem resolved. It took me awhile to figure out the problem as we were on vacation with our travel trailer east of the Rockies. Since it was raining every other day or so, I first thought it was rain water leaking into the cabin. - John
Tranny swap
I agree with @Mopar1973Man. Way too many gears that will never be used. Awhile back, I made a chart to compare some manual transmissions. I added the Eaton Fuller RTO 6610 (10 speed Overdrive) transmission. I think it could be a good option. 660 lb/ft input torque and transmission weighs in at 359 lbs. Very uniform close ratio transmission. - John
Tranny swap
The 1.24:1 is still an underdrive in 8th gear on the 613 transmission. The 613 had two choices - direct drive 1:1 or 1.24:1. No overdrive. - John
2006 Dodge - Thor - Track Bar issues
Good catch on your part. I think this happens more frequently than is ever mentioned. This type of bushing contains two parts. They each have their purpose. One part is a flexible bushing that is intended to flex and absorb energy. The other part is an internal steel sleeve that is slightly wider than the bushing. Its purpose is to ensure the assembly can be clamped with enough force between two steel ears that the steel sleeve will never move. This type of bushing is also used for leaf spring hangers and shackles as well as some shock absorber mounts. Proper torque for the fastener may be set correctly, but this does not guarantee that the ears (usually welded onto the frame or axle) are bending enough to reach their full clamping force on the inner steel sleeve of the bushing. For this reason I usually torque the fastener to a higher value to ensure good clamping force. I follow up with an inspection after a couple of thousand miles to check for tightness. @Mopar1973Man, since the track bar connection on your truck has been loose for awhile, the steel sleeve and / or ear mounts will wear some, possibly removing material. This will make it harder to attain the clamping force when the fastener is re-tightened. I recommend inspecting the connection again after a few hundred miles. - John
Tranny swap
@David E, I can't help you regarding the adapter, but I am interested in your project. Would that Roadranger be an 8 speed? I always thought that this transmission would be an excellent choice for a Dodge Cummins powered truck. - John
Anyone ever wonder what you would do if you find squatters in your house?
Can you give details as to what transpired here? Example: was the home unoccupied for a few months first? Or, were the owners gone for a couple of weeks (vacation)? Or, did the owners go to the grocery store and return to find people occupying their house? Could make a difference on how to prepare by knowing what you are up against. - John
VP 44 home made brains part 2 getting real now
@Great work!, you are a talented man!! I couldn't even begin to take on that task. - John
Replaced injectors, engine almost stalls at stops.
@Thr333_Arr0ws, it may be that nothing is wrong. The following is only my thoughts, but it would seem to me that the ECM easily has the capabilities of operating stock injectors smoothly through all engine rpm's and engine loads, including engine idle. But, when you replace stock injectors with significantly higher horsepower injectors, then I could see that the ECM may struggle to arrive at and maintain a smooth idle. Look at it this way - the engine is going to use the same amount of fuel to idle whether it has stock injectors or high horsepower injectors. The difference would be that with the high horsepower injectors, the ECM would have to cut fuel duration time way back for the engine to idle at the same rpm. To me this could make it difficult for the ECM to precisely meter the exact amount of fuel required to make a smooth transition to idle with high horsepower injectors. I currently run RV275 hp injectors in my truck - that is only a 30 hp bump. While I have no change in the way the engine arrives at idle, I do now have a slight hunting in rpm's at times during clutch engagement. I attribute this to what I just mentioned above and consider it normal. Again, these are only my thoughts - no verification that this is even happening. There could easily be something else going on. - John
I am not going to be of much help here, but can you describe the above in more detail? Is this a rapid change in rpm - such as, 2 or 3 times per second? Or, is this a much slower change? Also, what were the previous injectors - stock, OEM, etc.?. Are the replaced Bosch injectors new, or re-manufactured? Do you know where the VP44 came from and did it come with a new PSG or a used / reconditioned one? I asked these questions because others more knowledgeable than me, will come to your aid shortly and they will probably want to know some of these answers. It sounds like the truck has been well maintained by the previous owner and currently by you. - John
Fan Clutch
Good to hear that you won with your decision to replace a defective new clutch fan. It's a bummer that you should have to do the job twice, but I am glad to hear the engine is running as it should. - John
Fan Clutch
Well dang! That shoots that idea. Another area to possibly look at would be to check if there is any dirt buildup on the front side and center area of the radiator. This collection of dirt is caused by crankcase vapors from the OEM location of the engine breather. It is very difficult to gauge how dirty it is. Years ago this occurred on my truck and would cause a minor heating problem on long grades with heavy loads. I spent several months trying to figure out the problem. I even installed a new clutch fan and nothing changed. Once I saw how badly the airflow was restricted (after removing the radiator), I cleaned it thoroughly and re-installed it. On my first test drive, I noticed the engine fan was much quieter under all operating conditions. Previously, the restricted air flow causes so much turbulence around the engine fan that the fan was noisy all of the time. The long period of time needed for the airflow to become restricted occurred so slowly that I never noticed the ever increasing noise of the fan. Not saying this is your problem, just trying to cover all bases. Might worth giving the fan a second chance by driving the truck for awhile after the engine reaches operating temperature. - John
Fan Clutch
When you are checking out your new clutch fan, are you checking fan operation without driving the truck? If so, it would be normal for the fan to be in full lockup on a cold start, or even a warm start. Normally, driving the truck for several blocks or maybe a mile or so, the fan should unlock. Can you give more detail on how you are checking the fan operation? - John
Mini Skid Steer Track Problem
I have a small mini-excavator - a 2007 Takeuchi TB016 with rubber tracks. I know it is not the same, but it is similar. I bought the machine used with 1550 hours on the hour meter. Still had the OEM tracks. At 2200 hours, because the rubber had many rips and tears, I replaced the tracks with new tracks from Prowler. Those tracks kept coming off - even when I was being very careful with turns. I tried various methods of adjusting them. I thoroughly inspected the undercarriage components and could not find anything wrong. Finally, after 140 hours of operation I removed the tracks and set the new and old tracks side by side for comparison. The OEM tracks were far superior. The photo below shows some of the differences between the OEM tracks and the Prowler tracks. The major difference was that the OEM's steel foundation for the guides was much more robust. The bonding to the rubber was also superior. The OEM tracks are shown in the upper part of the photo. The guides are in far better condition at 2200 operating hours than the Prowler tracks are at 140 hours. Also, the OEM tracks never de-tracked. I re-installed the old tracks and sent my documentation to Prowler. They gave me a full refund. I ran the OEM tracks for another 300 hours while looking for another set of tracks. I finally purchased a set from National. Those tracks are built much more like the OEM tracks. They are working fine (500 hours of operation now). I have de-tracked the Natinal tracks a couple of times, but each time was under severe operating conditions. I think that new tracks are more susceptible for de-tracking just because they have much more traction than the replaced worn tracks. Good traction with aggressive maneuvering can lead to de-tracking. You may want to give a close comparison inspection of your old and new track and evaluate any quality difference. It could be contributing to your problem. - John
Valve Lash Adjustment Question
No worries. - John
I based my response on what you wrote. You made no mention of using the VP44 gear timing mark or using Moparman's article. Now that you have clarified what you did, I think you have adjusted the valves correctly. This would be normal. Once you rotate the engine, some of the valves you adjusted will be approaching a camshaft lobe or just be coming off of a camshaft lobe. You will feel some looseness, but the proper feeler gauge will not fit in the space because the camshaft lobe is not in the right position for full clearance. Always double check your work and you will be fine. - John
No valves are adjusted with engine at BDC. With cylinder #1 at TDC compression stroke adjust: Turn crankshaft one revolution to #6 TDC compression stroke. Adjust the following: - John
Rear Disc ABS Options
Here is what I recall. All trucks from 1994 through 2002 have disc brakes on the front axles. 1994 - 2001 - front disc brakes and rear drum brakes, rear axle anti-lock brakes only (not independent rear wheel anti-lock) 2001.5 - 2002 - front disc brakes and rear disc brakes, four wheel independent anti-lock brakes I think the answer is yes. I believe the RWAL system uses a single sensor at the ring gear location - not a sensor at each rear wheel. It would seem that the ABS controller would not know whether or not the rear brakes are drum or disc. - John
