Tractorman
Joined
Last visited
Currently
Viewing Topic: P1688 with new VP44..help
Fuel Return To Tank (not basket) Question
Yes. You will note the added flat bar to hold it into place in the second photo. As for drilling the pilot holes in the corners, I only drilled the easy one from the bottom - the other three were drilled from the top after some measuring. I spent some time figuring out which places I could use bolts and nuts for fasteners and which places I would drill and tap holes for easy fastener removal later. I need to extend the fuel suction line on my truck at some point. Now I don't dread doing the job - plus, the fuel tank can be full and it still will be an easy job to remove the fuel canister. I am considering writing an article for this modification, but it will be awhile before I can get to it. In the meantime if anyone has any questions about how to do the project, feel free to ask and I will assist as best as I can. - John
Since I figure I will have my truck forever, I just modified the bed to allow access. The top of the photo represents the front of the truck. Many holes are drilled and tapped for easy removal. So much easier to work with! - John
Lift pump shuts off after engine starts
Here is just one of many vacuum gauges that would be suitable. Just make a temporary tee fitting to work for your test. You don't necessarily have to drive the truck. Just bring the engine rpm up to 2,000 and hold. This will bring the tank return flow to about 28 gph via the internal vane pump. Observe the vacuum gage reading. As far as a permanent fuel pressure gauge setup, I have no recommendation. I use a warning light mounted in the dash. The warning light is triggered by a low fuel pressure switch under the hood. I have never felt a need for a fuel pressure gauge inside the cab. I have also added a fuel line with a check valve that loops around the lift pump. This means that fuel flow to the VP44 inlet will not be disrupted in the event of a lift pump failure. The VP44 internal vane pump will continue to draw fuel from the tank and around the disabled lift pump. There will be no disruption of engine performance or fuel return flow to the tank. I have proven this with my own truck on a 28 mile roundtrip to town with the electrical supply disconnected to the lift pump. During the trip I applied full throttle several times, set cruise control for a few miles, and stopped / started the engine several times. No change in performance. Of course, the low fuel pressure warning lamp stayed on the for the whole trip (no lift pump pressure), but there was no cause for concern. - John
I used the same as above. No need to drop the tank. - John
The VP44 fixed displacement internal vane pump is the only pump that controls flow through the VP44 and over the 14 psi overflow valve returning fuel to the fuel tank. Because the vane pump is fixed displacement, it will always flow more fuel as engine rpms are increased, therefore more return fuel. None of the vane pump's operation has anything to do with the lift pump. The lift pump's only purpose is to supply more fuel to the VP44 inlet than the internal vane pump can use. That is all. Nothing else. Because the lift pump supplies more fuel than the internal vane pump can use and the internal vane pump is rpm dependent, there will always be a positive pressure at the VP44 fuel inlet. The fuel pressure at the VP44 inlet will be the highest when the engine is at idle and the lowest when engine is at full rpm under full throttle. I have logged similar miles on my truck (367,000) and over 270,000 miles on a replaced VP44. My frame-mounted FASS 65 gph lift pump pressure is the highest at idle - 12 psi. It is 6 psi at under near full power. The 6 psi is of no concern. It is a positive pressure at the VP44 inlet. I operated a OEM relayed in-tank lift pump (modified under warranty by Dodge) for over 150,000 miles on the replaced VP44 - that lift pump produced 6 psi at idle and 3 psi under near full power. Again, 3 psi is a positive pressure - no concerns. I think you are on the right track with getting a reliable gauge setup and installing a frame-mounted lift pump. The frame-mount pump will allow the lift pump to behave like a pusher pump instead of a puller. Most of the time the fuel level in the tank will be at or higher than the lift pump inlet. Lift pump pressure should be steady at any pressure reading. You mention you still have concerns with blockage. I think it would be worth installing a temporary vacuum gauge at the lift pump inlet (on your frame-mounted lift pump) to measure the pressure drop. If there is no blockage, I would expect to see a minimal vacuum reading (less than 5" hg) while driving the truck. I just noticed that you are reading the 14 psi overflow article. A good read, but in my opinion this valve is not your problem. The operation of this valve is largely misunderstood. It very rarely fails - if ever. - John
Squeak/Screech noise in reverse only
Sometime problems get figured out just by chance. If you would have kept track of which side the adjusters came from, then you would not have posted the above statement and you would have likely re-installed the adjusters on the same side from which you removed them. This, of course, would have been wrong and brake performance would have deteriorated over time as the lining wore. So, in this case, it turned out to be a good thing that you didn't keep track of which side the adjuster came from when you brought them into the garage for cleaning. Now you have good performing brakes and you did the work yourself and you probably learned a bit along the way. Good job. - John
Tire Size
Another good combination! - John
Tire Size
You forced me to go and find that song on the Internet. I remember it now, just never realized that was the word being said. Creedence Clearwater had a lot of good songs. - John
Tire Size
I would agree that your setup serves you well. "Choogles", that's a good word. - John
Yes. That is about 50 gph. Are you hearing this when the engine is running? - John
@IBMobile's test is a good one. One reason you are seeing the pressure fall off after starting the engine is because the fixed displacement internal vane pump inside the VP44 takes over. With the engine idling this vane pump returns at least 18 gph of fuel to the tank via the 14 psi overflow valve. The lift pump is not keeping up with that flow rate, consequently, the pressure falls after engine is running. Only two reason come to mind - the lift pump is faulty, or there is a blockage somewhere in the fuel line. It is not air. The lift pump can pump air mixed with fuel. If there was too much air, the engine would probably die and would not restart. but a gauge would still show fuel pressure. - John
Sometimes you know more than you think you know, but just don't use your own knowledge. I know, because I do it often enough myself. Here is a closeup of your own photo of the brake on the left side. Note that the threads are right handed (I believe that this adjuster is on the wrong side). I say this because when the lever is pulled upward by brake shoe action via the adjuster cable, the toothed wheel will rotate in a direction that will bring the bottom of the brake shoes closer together. It should be doing the opposite - pushing the brake shoes farther apart. You can hold the adjuster and lever in front of you and imagine its upward travel engaging a tooth. The action should increase the length of the adjuster. With that information you will know which side to install it. If it is in fact true that the adjusters were on the wrong sides (which I believe is true), this enforces my reasoning that just because you put something back together the same way you took it apart does not necessarily mean that the parts are installed correctly. Maybe others could look at the photo and post their thoughts. - John
Tire Size
Hey! Don't say "no one". I use that tire size! - John
First drive with VP 44 project
Oh boy, see what you started? Personally, I believe that computer controlled fueling for diesel engines is far superior in performance than mechanically controlled fueling, especially when it comes to tuning. However, I am very glad that my truck is not laden with computer controlled items like engine fan, or power windows / door locks, or a TIPM (3rd and later generation), headlights, 4WD, and so forth. For example, because my power windows are not computer controlled, I was easily able to rewire the control switch to operate the windows without the ignition switch being turned on. Very useful and simple modification. I think that one of the reasons I like my VP44 fueled truck is because of good performance, good reliability, and a reasonable cost for replacement parts - especially the injection pump when compared to just injectors on a fully computerized common rail fuel system. I find I am easily able to diagnose non computerized electrical problems with the use of an electrical diagram and a test light / digital multimeter without the use of diagnostic error codes. - John
@Andyba20, It is very unfortunate to have those repairs done so poorly on your truck. I am sure this is why so many who seek information from this forum are very leery of dropping off their truck to a repair shop. If your drums are in good condition (not heat cracked or out of round and are within diameter specs), you could probably just emery cloth them and install new shoes. Whichever way you go, the last thing to do before installing the brake drum is to use liberal amounts of Brakleen and a shop towel to clean the shoes and drums of any handling contamination. - John
You will have improved braking. If all of the shops performed excellent work, this forum wouldn't exist. Drum brakes have been on the way out for a number of years. When that happens, usually knowledge goes away with it. Here is a good story. After a couple of years working as a fleet maintenance mechanic for Copper Mountain Ski Resort in Colorado, I was promoted to shop foreman. We maintained a fairly large fleet - a dozen snowcats, heavy equipment, about 50 trucks and vans, golf course equipment, transportation equipment, etc. About a year before I started working there as a mechanic, the landscaping crew had purchased a 3 axle 10,000 lb GVWR equipment trailer. Apparently, from the day it was purchased, the electric trailer brakes never worked right. Over the course of a year the trailer was sent back to the manufacturer several times in an attempt to get the problem resolved. Well, it never happened. I saw other mechanics trying to figure it out from time to time, but without success. So, finally the landscaping crew gave up complaining about it and used it without trailer brakes. When I became the shop foreman, I asked my boss if I could bring that trailer into the shop and find out what is wrong with it and then fix it. He gave m the go ahead. So, I brought it into the shop and had all wheels and drums removed to expose the brake hardware. I offered every mechanic an opportunity to figure out the problem. But, I also said that nothing could be disassembled until the problem was resolved. I told them that I thought whatever is wrong with the braking system is going be simple and fundamental, and left them with that. Throughout the rest of the day, I had conversations with several mechanics about the problem, but after each discussion we would rule out that possible solution. The next morning with a fresh cup of coffee in my hand, I looked at the brakes on both sides of the trailer. I began to chuckle. The problem was obvious, but I didn't notice it the day before and I had looked at it several times, myself. I let all of the mechanics know this information and I gave them two hours to figure it out. No one did, so I gave a hint. I said, "Remember one time awhile back when a mechanic said that when does a brake job, he leaves one side assembled so that he has a reference in case something goes wrong? And at the time I made a remark 'what if the referenced side is assembled incorrectly?'" There was silence for a moment and one mechanic piped up and said, " The axles are on backwards". He was correct. All three axles installed incorrectly by the manufacturer. Needless to say, we switched the axles around, put on some new brake hardware, and lo and behold, the trailer brakes worked great! Made some people happy in the landscaping department. - John
Thanks @SVALIN. I was just trying to visibly see that there is more brake lining on the secondary shoe. It appears that is the case. The brake shoes should be the same size, but the brake lining should cover more area on the secondary shoe. There can be brake lining thickness differences and material type differences, too. Usually, the primary shoe would have the thicker lining than and cover less area than the secondary shoe lining. It will interesting to see what the other side looks like. - John
@SVALIN, would it be possible for you to post a photo that would show the bottom of both brake shoes? That way we could see the difference of the primary and secondary shoe. - John
You are performing some good troubleshooting here - you are definitely on the right track. It sounds as if you still have the OEM lift pump circuit. If that is the case, the ECM provides power to the lift pump with two circuits - one for engine start and one for engine run. The ECM is carrying the full electrical current load for the lift pump - not the best design. If this is your problem, relaying the lift pump using the ECM to provide power to the relay coil would be a good solution as long as the ECM is still performing properly. This modification would reduce the electrical load on ECM lift pump circuit considerably. In the worst case scenario (ECM no longer supplying power to lift pump) you could use a switched circuit in series with an engine oil pressure switch that would supply power to the coil of a relay for the lift pump. This would accommodate the "in case of an accident" feature. If you are referring to the relay in the PDC, this relay is for the fuel control solenoid inside the VP44 injection pump. It has no affect on the lift pump circuit. - John
With the information that you have provided, I recommend to take the other side apart for inspection. This way you can replace what you need, but most importantly, you can adjust the service brake and parking brake properly. You can verify that all of the parts are assembled correctly, as well. One important part of drum service brake adjustment is specifically observing that both primary and secondary brake shoes are seated against the anchor pin on each side of the vehicle before adjustment. Here is what can happen. A mechanic installs the primary and secondary shoes and hardware on the left side. He ensures that the shoes are seated against the anchor pin and installs the brake drum. He goes to the right side and installs the brake shoes and hardware. He notices that both shoes have not come up against the anchor pin, so he pushes them against the anchor pin. He believes all is well..., but maybe not. What can happen (and many times does) is that when he pushes the brake shoes against the anchor pin on the right side, the energy from that action transfers through the equalizer in the park brake circuit to the park brake actuator on the left side. Consequently, the primary (forward) shoe is pushed away from the anchor pin on the left side. This will result in improper service brake adjustment and improper park brake adjustment. The usual cause of the above-mentioned issue is someone (during the life of owning the truck) adjusts the park brake cable (along the driver side frame) when the service brakes should been adjusted instead - or at least, first. At the very least, I recommend that you loosen the park bark adjusting cable considerably before adjusting your service brakes. Then, after service brake adjustment, follow up with the park brake adjustment ensuring there is a bit of slack on each rear wheel cable at the equalizer. This will allow for full brake shoe contact to the anchor pin at each foundation brake. - John
My recommendation will be based on your answers to some questions regarding the rear brake history of your truck. Do you know if the park brake cable has ever been adjusted (the cable adjuster on the driver side frame rail). If it has been adjusted, was it done correctly? Have you replaced the rear brakes recently? If so, did you do the work or did a shop do the work? How many miles and years on the current rear brake parts? - John
That is good information. I can't say that I can detect the "creaking" noise in the video. Something that comes to mind is I believe someone posted on this forum (or the TDR forum) about a cracked or loose flex plate. If I recall correctly (which happens less and less), the noise only happened in reverse, which seemed odd. It had something to do with how the torque converter operates differently in forward than in reverse. I don't remember the details. If a failing u-joint is suspected to be making the creak, there is an easy test to eliminate or confirm this without removing the drive shaft. A u-joint that is failing to the point of making noise generates heat at the exact failure point. Take the truck (after setting a few hours) for a drive. After no more than 5-10 minutes of driving, pull over and feel each post on each u-joint by hand. If there is a significant temperature difference, you have probably found the problem. I have used this procedure a few times and in some of the tests, I actually marked the posts on the u-joint where I felt the heat. Each time, upon driveshaft disassembly, I had correctly identified the failing post / posts. - John
Watching the video a couple of times, I agree that the "moan" seems to be in cadence with a tire revolution, not a driveshaft revolution (3.55 turns per one tire revolution). Also, the previous posts and video are not clear as to whether or not the truck operator is controlling the reverse speed of the truck with the foot brake, or if the transmission selector is in "reverse" This information could help with troubleshooting. - John
I agree that this is dangerous, but I just wanted to clarify what W-T posted. He does not mention anything about starting the engine and shifting into a gear. He does mention to "hand turn the tires". - John
That is one impressive video!!! - John
