portlandareae28
Everything posted by portlandareae28
  1. Forgive my ignorance on this one Mike, I have not spent much time yet learning this fuel system. Is the regulator internally in the pump? or is it external?
  2. Filter or electrical? 74E8D060-977B-4DC8-AB17-0FACB8B9EB23.MOV
  3. You might have to, if you want glass mayonnaise jars you are going to have to go to an antique store :-)
  4. We used to do our VW bugs this way with beer bottle instead of mayonaise jar, did all 4 wheels at once :-) :-) :-) We would use coat hangers made to stay in the jar and hang them too (kinda spring loaded diamond shape hanger forced into the bottle)
  5. Does anyone regularly use a power bleeder here? Whether vacuum or pressure? Pro's/Cons? I am thinking I want a vacuum style as I have multiple cars and a pressure style would require many caps. I don't always have a helper when working on the cars and its time for fluid flush on the truck and my car. Thank you
  6. Update. This truck is in this thread earlier with a leveling kit and 35's but I can attest to everything I have read and learned here, the trucks run and drive much better stock..... 345,000 will always need something.
  7. Mike, Truly my pleasure! You do more for people with no expectation of anything in return than 99% of the people on this planet. I have not always been in a position to financially help others in my life but I am currently blessed enough to do so and helping someone like you is a given in my world. I talked with others here after I spoke to the machine shop and I think others would like to participate in helping you in a tight/tough time. I don't see you as one looking for handouts but maybe we could set something up on the website for others who feel as I do about you and the value of the site. I wish I could have paid that whole bill for you, you always answer with Grace my dumbest of questions and have helped me and I am sure many others here through the simple and tough questions. I ask all members that Mike has helped save $20-$1000'S to pay it forward. Many small contributions will make a BIG difference. Mike I ask that you recommend that machine shop to any and everyone in your area!! Great group of guys to help me. If I need a head rebuilt I might just ship it to them. Happy to be able to help a man who has helped me directly and indirectly more than he will ever know. THANK YOU MIKE!! Brian
  8. http://www.lmctruck.com/icatalog/de/full.aspx?Page=45 My truck needs them too, doesn't look fun getting up in there. Who has done the bushing swap?
  9. Ever get anywhere on getting this solved? I may be in the same boat. Can feel the pump in the pedal and the steering feels like it’s struggling at times.
  10. Do you know what Betty's name is here so I can send her a private message to see if she is interested in working on the truck? She is about an hour/hour and a half away but that is fine if it means I can find someone who knows and loves vp 2nd gens to work on it. Thank you Brian
  11. Anyone know of a good Cummins wrench in this area? We just moved here and I don’t have time for a few needs on the old girl. I am willing to travel some for a known good wrench. Any help is appreciated!! thank you brian
  12. Should the front link bolts come out? They don't seem to want to
  13. Anyone have a hardware list for sway bars? I have a set that came with the truck, but no hardware.
  14. Fuel was cheaper in California than Seattle last time I was down there 2 weeks ago. I am going to continue to read up on all of the systems, just hard to argue with the guys here. And tough at times to find solid factual information.
  15. Do share your thoughts/reasons. Seems like most everyone likes their AD's
  16. Do that setup with what pump setup? Funny I had to fix the drain valve on the filter canister yesterday.
  17. I am moving to California at the end of June and think maybe I don’t want to test the DDRP for the 1200 mile trip towing. I am trying to figure out which system makes the most sense, and if it comes with everything needed for the install. This truck is stock except edge comp (not tapped currently due to not having a fuel system). It will never see more than a 75-100hp injector (assuming I can do anything in the people’s republic of California) Fass, airdog, or?.. which model and why? what do I need in addition to the system for install? Hoping to not have to drop the tank before I go as I am running out of time. i appreciate any and all help/opinions. (I may be open to the belt driven mechanical pump setup) thank you brian
  18. Is there a way to shut the alarm off until I figure out why it continually is going off? I think I have a door lock issue and it goes off EVERY time I open the door. would be nice if it were just on a fuse, though I could see that being very pointless once a thief figures out where that fuse is
  19. I am digging this setup!!
  20. https://www.vulcanperformance.com/Metric-Adapter-08-JIC-X-12mm-p/m1208.htm 06 or 08JIC?
  21. I did a 1/2" or 5/8" drawstraw in my Ford, I still have some of the stainless pipe, could just get a bulkhead fitting and get busy. Guess I should do a little digging on what people are doing for pickup that works well
  22. to increase the fuel lines from the tank I am going to assume is going to require dropping the tank and modifying the pickup as well? I did a Draw Straw and built the regulated return system on my 7.3, just still learning my way around this truck a little bit. I could easily run 1/2" from the tank if no mods are needed to the pick up itself, but I am going to guess the pickup that is stock in that tank is not engineered to move this much fuel. Actually there was a tank for $50 or less on Craigslist, wonder if the guy still has it, could clean, it, build it and swap them. hmmmmm.... I will be upgrading the pump sooner than later, but this all has to be done anyway, so may as well get started.
