Looking for Staff Members
wagntagn
Everything posted by wagntagn
  1. the info on my 2001 ram 2500 are in the glove box,the# are faded,the only thing I have is the serial #1B7KF23651J555993 is there any way I can find the right paint color # in the s/n,by the way my truck is 2 tone black & silver:(
  2. 5" DIAMOND EYE sounds good but do you keep the 3' exhaust pipe or you go bigger?
  3. good info, I think Ill go for 5w40,staight or synthetic? what is best I was told synth, ain t the best for diesel
  4. In northern Canada we get weeks of -20 to -35 celsius my body told me Ishould use regular 10w30 gas engine oil better on start up,he said I should stick to 10w30 as I won t be pulling much,I ll be using the truck mostly for hunting & fishing,What s best??
  5. Good subject,I want to increase the size of my muffler where do you start the increase ,right at the manifold ?Of what I can see the bigger the better,no restriction is best for power what about fuel economy?
  6. Great ,thanks for the info I ll check the ground to start:)
  7. Up in the" BOONIES" northern Ontario,just bought the cummins with a defective transfer case,I did those repairs & now I want to make sure I have enough fuel press. before I start on the modifications.0 psi is not enough ,I ll replace the transfer pump,I m worried about the 8 volts I have when I flick the switch,this can be hard on a 12 volt pump
  8. what happen is I wanted to check the pressure between transfer pump & vp44 ,my gauge was reading 0 psi so I unplug connecter on transfer pump & check voltage with my meter and the results were with key on 12 volts for 2 seconds then voltage went down to 8 volts ?then I turned the switch to start & let go I was getting 12 volts for 25 seconds & then the voltage dropped to 8 volts until I turn switch to off ,voltage dropped to 0 ,why is it staying at 8 volts you would think it should drop to 0 volts.Afterwards I pull the pump out and it s seized so ordered a FASS pump as replacement,Ijust want to make sure of the good voltage before I do the switcharoo.
  9. Does anybody know the voltage when starting .When I turn the switch to on I m picking up 12 volts for 2 seconds & then it drops to 8 volts? Then when I turn the switch to start & let go I get 12 volts for 25 seconds then voltage drops to 8 volts? Why does it drop to 8 you would think it should drop to 0 volts.These test are done at the transfer pump connector.
