Everything posted by wagntagn
lift kit for 2001
Right on man,today is installation day ,levelling kit & tires thanks again:hyper: --- Update to the previous post... levelling kit installed,tires back order have to wait till monday
lift kit for 2001
when you install the 2 " levelling kit are you better to go with longer shocks,do you need to go with special rims so your tires don't rub against the frame?
lift kit for 2001
good one , I'll try the ratchet first
lift kit for 2001
UCAs what do you mean by that,I'm at the point my springs are out I need 1" to make 'em fit,some one mention you have to compress the springs?
lift kit for 2001
is :cookoo:there a trick on installing the spacer,the only way I see it you have to compress the springs
4x4 switch?
great guy's,that should be an easy one!!
4x4 switch?
I'm not getting any indication on the instrument cluster that the 4 wheel drive is engaged but everything works fine,where is the indicator switch
lift kit for 2001
is that all you have to do to fit 35's? --- Update to the previous post... I was told you need longer shocks? --- Update to the previous post... the shop in my area wants to sell me some mito toyo 315 75 16 at $159. each and polished aluminium rims at $ 175. each,are aluminium rims OK for the cummins pick up?This is canadian $ I think the pricing is OK,do ypu's guys recommend a different tire?
lift kit for 2001
mine is the same it has the extra leaf ,the guy had a fifthwheel,so I don't have to do change anything in the rear,so what do I have to get for a levelling kit,Iwant to fit 35's
lift kit for 2001
what do you get in a levelling kit?How's the installation? So a 2" levelling would do the job for 35" tires
lift kit for 2001
some guy's told me levelling kits aren't the best,they recommend the lift kit
lift kit for 2001
I want to install 36" tires what should I look for a lift kit or level kit & how high should I go this is on my 2500 series cummins
transfer pump switch over
didn't have to call,my buddy at the shop had 2 banjo fittings in his junk box and they happened to be the right fit.....thank GOD!! next step hook it up and give it a shot,thanks GUY's,eventually I ll have the cummins on the road:pant:
Thanks MAN ! I'll give them a call
what's the thread size on your pump,your push lock what do they have for threads,your fuel lines are they hard plastic or rubber?
what's the thread size I need to buy a banjo fitting --- Update to the previous post... One of my Buddy told me it's a M 12x1.5 (metric) I'd like to know the lenght also,did anybody ever installed a FASS pump?
this dorman fitting is on a stainless tubing and goes back to tank,whoever replaced the pump must have change the old set up,if I cut the stainless tubing what is the best way to adapt the flex hose with the banjo fitting to the suction of pump/
P0230 Error Code
your right when I was testing the fuel system,the transfer pump would seize up at time the vp44 must of struggled,once I replace the pump I'll erase the code and see what happens,thanks man!
as anybody seen that pump set up the suction is a solid tubing with quick connect
P0230 Error Code
what is the fix ,my truck as the same code
where's the papetr clip,Bud ?
engine oil 15w40 or 10w30 (winter)
I'll go with shell rotella t-10w30 h.d diesel oil,Ill keep it pugged in on cold days,thanks for the info guy's:smart:
I'm replacing my transfer pump the one on the truck is not the original one,I bought a FASS DDRP 02.The suction is a different style fitting,it seems like a stainless tubing with a quick connect,did anybody ever experience that,to adapt the FASS pump I need to cut the stainless pipe and adapt some kind of a fitting ,in my package they sent me 2 banjo fittings /filter/rubber hose.Not sure what pump they had in there,the suction tubing must have been replaced that quick coupler seems like a good set up,it would be a waste to remove it.:duh:How can I attach pics to my thread
trying to find code # for paint
thanks guy's found my codes px8 black/clearcoat & ps2 bright silver metallic/clear coat ,the clear coat is this applied after you paint or is it in the paint? Can anyone help:cookoo:
