scubieman
Everything posted by scubieman
  1. I guess I will test ph tomorrowI mentioned . Towing because if I towed a lot I would do 180.
  2. How much it cost for flush and all? Coolant filter worth it? 190 or 180 t stat. I don't pull a lot
  3. According to ram it needs to have HOAT.
  4. Very nice. I thought these engine needed certain type of coolant fluid. How you flush anyways?
  5. Good sir, what kind of fluid is needed. And how do you flush?
  6. How often change fluid? Do we flush?
  7. I'm more worried about too low.If you need more info about 6.7 I have owners maintenance manual
  8. Well I think high/ regular is 11.5. I just know too little pressure is bad.
  9. Just kind of wondering what red light or too low of fuel pressure would be for 6.7. I know factory specs is 11.5 and I'm normally about ten. But I know 3rd gen I believe that 10 psi is way too low. I think they have the VP pump, unsure.
  10. Is this to make our trucks more foreign? Next will be fart cans
  11. For 65 bucks you can buy the plug in adapter wire kit in bed. Its all plug in and no cutting of wires. Just the box
  12. One other thing. I have 8 to 11 psi fuel going into cp3.According to specs it is suppose to be 11.5.I have after market larger hose going from fuel filter to cp3. Unsure when it loses pressure it sucks air.
  13. I used my truck this morning to bring kids to day care then to work.When I started the truck at home it started fairly quick,When I went to leave daycare that thing had to crank and crank then finally after about 3-4 seconds in finally started.It does not do this everytime. No error codes I can see(check engine light is off) I never hooked the programmer up to read.
  14. Yup, that's the weather temp. I believe it's 50 some degrees when the turbo wont whistle when on idle. The whistle means the turbo is engaged. It causes more work for engine when it's cold to warm it up faster. It's designed that way.
  15. Were you idle or going down hill with whistle? I know at idle it will only whistle if cold. And in motion will only whistle when warm.
  16. I second this
  17. Not sure. I got lifetime maps free with purchase. Don't throw box away. It has your codes to get free maps.Remember reviews are more from people that are pissed. I'm happy and no review yet.
  18. I highly recommend the tom tom with free map updates. I use my tom tom like a few times a year and great to be up to date. Also mine has traffic report in case there is a accident . It tells how long you will be delayed and where. Same with construction it will tell where it is and how long you will be delayed. Its great using through Atlanta.
  19. Well I am using a cheap Chinese one that was shipped from china. I like it cause you can rotate it. Plus I won't mounting one on back of fifth wheel. But I don't want to pay 400 for edge for a fixed camera.
  20. Does any other cameras work with the edge? I thought about replacing gauges with edge.
  21. Link dead
  22. Anyone have backup camera? If so show a picture of where located, I am as bad as a girl trying to find location.
  23. My dad has a hemi. His will kick into 5th unloaded. Pulling 11 k fifth wheel I barely see 5th with my cummins.Plus fuel in oil sucks but nothing is prefect. Like v8 diesel in a medium duty truck has no room for extras or to work on basics.That said my dpf and egr are missing. Or on shelf
  24. Do you know how the coolant flows through a 6.7?
