int3man
Everything posted by int3man
  1. You assume that Thieves can read!!! Oh you said computer. If you want to keep it a secret put it in a book I guarantee that the Thieves won't find it!!!
  2. I had one of those on my 2001, on the 5 v sensor power wire. The joint measured 1500 Ohms. So much for a good connection. Michael
  3. I'm sure my issue was low batteries and a weak Circuit breaker!! I'll try the Eaton version, as soon as it gets here. With this Covis-19 Crap I haven't been driving the Truck, and the batteries get flat from sitting. Heck we drove the wife's car for the first time in 2 months and the tires had flat spots from sitting. We did practice social distancing for the 4th. Drove up in the mountains and went 14 miles up a forest service road and had lunch at the crest of a hill, no fireworks but a Heck of a view!! Michael :- )
  4. I concur, my breaker tripped after I started the truck after sitting for awhile. Truck reved up to shift and breaker popped. Reset the breaker kept the RPM below or at 2,000 RPM and continued on my trip. Long Term, I'll be looking for the Eaton breaker. Michael : - )
  5. Well if you want to do something nice for your ECM, next time the batteries are disconnected, remove it and clean all the ground connections, mounting points and the electrical plugs. Just a suggestion. Michael :- )
  6. Hi All, Wondering if anyone has a found a list of Brake Rotors by bolt pattern and then diameter and offset? My 73 interceptor has a toasted front rotor and I need a pair. Found some in Australia, that were reasonable but the Freight!! OUCHH!! So I know that they didn't reinvent the wheel but no one stocks them. It is a 3 caliper system from the rebuild kits available. I'll Yarf it apart tomorrow. These guys list them as rear Rotors from Jag but Rock Auto shows all the Rears as being 4 bolt pattern. So it's a 5 on 5 I'm pretty sure, B / E body. https://www.ebay.com/itm/Jensen-Interceptor-MK-I-6-3L-V8-1968-1973-FRONT-DISC-BRAKE-ROTORS-RDA73-PAIR/281925936090?_trkparms=ispr%3D1&hash=item41a41863da:g:eVMAAOSw-NBdRN2B&enc=AQAEAAACUBPxNw%2BVj6nta7CKEs3N0qUQ3VumwLXJRzYhPGXyyVWV%2BuU%2FdvU9y%2FdbuYcl6VqrN4XcX0qEa8QnQtoEGeLFua0oLPV7iUTJQEjfNt2LHQguMRgMTniN1YKPniV3bFp5qteldJA0XGI4a3R7h1%2BTXU312miV%2FK%2FGUfwZydrIiWtX3%2ByC2B6%2Fy5V3mLZPOLgjX7CgqkXth8qBXSqitSUaepn2DPPUZKtOrf09WbqMENj7bBSccZspRHwNUKSS2WtDn9mlUpVYBrBFEgK%2FZZwz98vSOJ0vOQLAIaKOzxX3VK8K54Bwz5DXDAFawn8l%2B%2FxJZ3vbRSU14%2BJJJ874oncsW%2Fp%2BchhmTqECj3N8YASNc1zISVi3zrNUjSueK9QXOWOyFjZnqHlE9Dh4C65uZGaWYsPxNTIoBrGe409y9I8dvdq5H32qQPy%2BVg26CAEHje5w6HqXcQf%2F9GilMbNdx3x3jQBXxc%2F1RN45OHsTGeQKiDjjyKTme5QAMNuJoBzUBks9OFYyXTL1tW54s3uQqUBr9kv7PKyz6JlCqmnTgZ9Lnmf1mavog7dxlN3Mz8Sd9rkfDHG6geUYof%2BOcs7CmoaYqqoqvyT%2FMnDF1f5s4rK%2Bk8oZ%2FAUzC5kmh2AZslAtBemkkFOlBovctSxegwNWUDtHVEGMNTE1mUSH%2BV2WRqP57xSOOCNqCeQbk%2BTjllzm8L4o68HkVNByl6j6f9HJXoKu0AlP6g51ygiI%2FsmSFdSv7s%2B%2FlJHzA4MkNeWKxczt%2BQRrZqAqv2alLioN1bahUnrxftw%3D&checksum=281925936090e419241f09094d9590d10619f30f87d6&enc=AQAEAAACUBPxNw%2BVj6nta7CKEs3N0qUQ3VumwLXJRzYhPGXyyVWV%2BuU%2FdvU9y%2FdbuYcl6VqrN4XcX0qEa8QnQtoEGeLFua0oLPV7iUTJQEjfNt2LHQguMRgMTniN1YKPniV3bFp5qteldJA0XGI4a3R7h1%2BTXU312miV%2FK%2FGUfwZydrIiWtX3%2ByC2B6%2Fy5V3mLZPOLgjX7CgqkXth8qBXSqitSUaepn2DPPUZKtOrf09WbqMENj7bBSccZspRHwNUKSS2WtDn9mlUpVYBrBFEgK%2FZZwz98vSOJ0vOQLAIaKOzxX3VK8K54Bwz5DXDAFawn8l%2B%2FxJZ3vbRSU14%2BJJJ874oncsW%2Fp%2BchhmTqECj3N8YASNc1zISVi3zrNUjSueK9QXOWOyFjZnqHlE9Dh4C65uZGaWYsPxNTIoBrGe409y9I8dvdq5H32qQPy%2BVg26CAEHje5w6HqXcQf%2F9GilMbNdx3x3jQBXxc%2F1RN45OHsTGeQKiDjjyKTme5QAMNuJoBzUBks9OFYyXTL1tW54s3uQqUBr9kv7PKyz6JlCqmnTgZ9Lnmf1mavog7dxlN3Mz8Sd9rkfDHG6geUYof%2BOcs7CmoaYqqoqvyT%2FMnDF1f5s4rK%2Bk8oZ%2FAUzC5kmh2AZslAtBemkkFOlBovctSxegwNWUDtHVEGMNTE1mUSH%2BV2WRqP57xSOOCNqCeQbk%2BTjllzm8L4o68HkVNByl6j6f9HJXoKu0AlP6g51ygiI%2FsmSFdSv7s%2B%2FlJHzA4MkNeWKxczt%2BQRrZqAqv2alLioN1bahUnrxftw%3D&checksum=281925936090e419241f09094d9590d10619f30f87d6 Thanks in Advance Michael :- )
  7. Huh I thought that the AC ran in Defrost mode to dehumidify the air. At least the Cadillacs were that way. Michael :- )
  8. Well I was out in the front yard today and found the foil that came out, when I back flushed the heater core. At least it was this color that flashed by in the clear hose. So the P.O. didn't do a good job of policing his trash. Michael :- )
  9. O.K. Bought some hoses and fittings and back flushed. Got a piece of something out of the inlet when I back flushed it. Looked like a leaf or a piece of foil seal that you cut out of a antifreeze container, I didn't capture it. So I took the truck for a drive and low and behold we have Heat. Not blasting out the defrost vents but the face vents are blowing warm / hot air, and at hot higher volume. So I am going to wire tie off the recirculation door so that it stays in the recirculation mode. I can remove the 2 nuts and slide down the actuator and tie it off actuated. Thanks for the assist!! Michael :- )
  10. O.K. Found the post to the HVAC removed. The Heater Runs 24 / 7 weither it allows air to flow over it is the job of the Blend door it controls the air flow from the fan. The recirculation door is vacuum operated. And it looked like the Evaporator was the dirt filter. So HUMM I think I'm back to flushing it. Michael : - )
  11. Yes Sir both hoses are hot! Doesn't the AC use the same air for cooling. It can't because the Heater core is hot all the time. HMM are there separate fresh air inlets for A.C. and Heat? No it would cost too much. HMM Michael: - )
  12. O.K. So I taught the kid about Series and Parallel batteries. I asked if they had a carbon pile tester, to test under a load and they looked at me like I had 2 heads. Next time I'm taking my hand held Snap On Heater (Battery load tester) and BLOW their minds!! So looking at the heater hoses I get it now the heater core is active 24/7 I thought that it was like my normal Mopars and there was a heater control valve but there is not. So I think that my heater core is plugged and possibly the air inlet. When I go on MAX with the AC the wind will blow you out of the truck when I go defrost you can feel a movement of air but it is cold. So if the water is not circulating in the core, then I am blowing outside air against he windshield, that is why it is cool to the feel. So Back flush and forward flush it is. Anyone know the hose diameter? Thanks Michael :- )
  13. HI John, Yea that confirms what I was thinking. The blend door is full over so there is no flow through the heater core. I'll work on flushing it tomorrow. Any one know what the hose size is off hand? I have to take the truck in to get the batteries tested tomorrow. Thanks! Michael
  14. Thank you sir you are a gentleman, in spite of the feathers!! And please see how much air you get through the defroster? Same as the face vents or about 1/3. I get about 1/3. Once I got the Air door to hot I was able to warm the windshield. Michael :- )
  15. Well I did the same thing. I kicked the door to hot and turned the AC on MAX Blew Lots of Cool air. That's why I am confused. Thanks Michael :- )
  16. Hi John, That is true, there is air movement but nothing like the A.C. Blowing on max. And MAX recirculates the air. HMM I wonder how to get the MAX feature on while the heater is on. I tried it with the Blend door moved over but it was cold air. Defrost is moving air but not at the velocity of the MAX A.C. Hope that is clearer. Michael
  17. I'm going to try flushing the heater core back and forth, see if I can get crud out of it. It was an Arizona Truck and probably never had the heater turned on. Thanks Michael :- )
  18. O.K. TOTALLY Weird now. Finally got the back screw out. Actually a friend did, I don't fit stepwells anymore. And the intermediate part was good and the servo motor was tracking unloaded. So the last turn to cold the motor did not stop must be trying to shut the door and can't because it is hanging loose. So we manually kicked the door to heat and I have a little heat but no large movement of air. If I Kick it to max A.C. it blows Cold Hard, through the face vents. Is there a way to flood the airbox to wash it out? I know on the Megacab had a drain nipple that keeps the bugs out to eliminate the condensation from the A.C. Thanks Michael
  19. Nope not yet. Just getting into it. This really Sucks!! I tried a 1/4 flex socket with a bit in it and it bent too much so I'll try some tape tomorrow. Post photos when I get it apart!! Check out the Heater treater link below. Michael :- ) https://heatertreater.net/dodge-ram-95-02
  20. O.K. Reached in between the door motor and the heater box. I was able to spin the output shaft continuously. So it is a toast. I'll get it pulled out. The Heater Treater looks pretty simple to emulate. A Stepdown Copper reducer might just do the trick. We'll see. Michael :- )
  21. Hi all I redid my terminals last winter and conversion to Military terminals. Now the Batteries are showing their age. Time for replacements. West Coat Central Valley TIA Michael So looking online Amazon offer Optima's for $199 720 amps Batteries plus 750 CCA Group 27 for $149 + 20% off and a $10 mail in rebate. Kind of answers my question. Thinking of selling and getting along wheelbase.
  22. Yes sir we have air just no heat. Hot Water hoses. Don't know how hot but as described hang on to the outside one and not the inner. Thanks! Michael
  23. Hi All, Got in the truck to get the Christmas tree we are having our first good storm of the year in Northern CA. So we drove with no defrost and foggy windows. Reading the trouble shooting options the hoses are both Hot with the right being hotter, no hot air blowing anywhere If you turned off the fans and idled I did feel some heat but not enough to warm the cab. Looking at a trip to Seattle at Xmas time this isn't going to cut it. Is the Heater Treater still the hot ticket for this issue? Thanks Cold in the Central Valley!! Michael
  24. Hi Nope sorry, I didn't try as I live in a hands free state! The tablet on airplane mode works great.
  25. int3man replied to Laura's topic in 3rd Generation Dodge
    I've got an old Smarty I'm willing to part with. Just sits under the drivers seat. My transmission used to knock your teeth out when it shifted. The PO had some sort of Race Tranny fluid in it. Paid to have it flushed as it was new to me and voila shifts nice and tight but doesn't kick you in the pants with every shift!! Michael :- ) OOPPPSSS Sorry just reread this Gen 3 sorry out of my sand box. The Smarty is for my 2001. The tranny did shift better after the fluid change.
