Banks high flow intake elbow and OEM grid heater replacement
I know this is an old thread, but thought I would mention, I just seen where Banks is offering a 2nd, 3rd & 4th add on heat element available to add to your intake. Just FYI
Beast - 500k miles - Projects
Well, I did get a new Quadzilla Adrenaline, I found a dealer who had it listed at a great price (I believe it was a lower price than what was allowed to be advertised) & they matched it. Of course I have purchased a few thousand from them over the years. (Looks like I will be making additional purchases be it I have two to maintain now. (you've been doing that for a while now, it's a lot at times) On another matter, since I repurchased my 1999 2500 back, I am changing out the the front suspension, thus far I have purchased Thuren Fabrication track bar & their XS front springs, Bilstein shocks to match the travel & Stryker off road control arms & RXR some of the bushings, etc. One thing I find interesting is if you ask 3 different fabricators how to install all this you'll get 3 different answers LOL. I'll try to do a write up/pics for some or all of it for the website if your interested. It would be my first write up so can't promise the level of quality, but I do promise a LOT more detail/info than what Stryker has on install. (see install video from their page) I thought it was way to casual be it they didn't say anything about how easily someone can get in trouble if they simply just start ripping control arms off. LMK if you would be interested in a write up & if so any tips would be appreciated.
Was just reading your post from December, that was an expensive Jump start. Ouch. I just received my Quadzilla from DAP. Congrats on 500K miles. I thought I had a long to do list for my truck until I read your list.
Diesel Auto Power
Do we get any kind of a discount buying through DAP? Specifically I am wanting to purchase (again from DAP) the quadzilla with iQuad. Thank you
OmahaGen2 started following Diesel Auto Power
Suspension fun!
Be very mindful of your tire ratings, I've seen that sneak up on people a few times. I pulled our trip axle 5th wheel all over the country (with my 2013 dually) One thing that made ALL the difference in the world was a air ride hitch (https://hensleymfg.com/) They are a little spendy, but worth every penny. they save your truck, trailer & you smoothing out the road.
OmahaGen2 started following Suspension fun!
Mr. And Mrs. Michael S. Nelson has occured!
And the hit's keep coming, sorry your going through all of it, but like you said the perk of being married.
Well I came back to the site just in time then. Congratulations!
OmahaGen2 started following Mr. And Mrs. Michael S. Nelson has occured!
V06 recall No Weld Fix trackbar replacement
I bought my 2013 with 118k miles & all welded up. I took it to the dealer for a all wheel alignment, when I got the written report back from the tech it stated, alignment within spec's, but would have adjusted it further had it not been welded. My complaint was the front tires cupping, "Viola" Ram responded by paying to replace the drag link. Pretty certain I am going to go with Thuren track bar & front coils (Thuren's Overland leveling system)
- 1 review
- 1
2016 Ram 6.7 cummins p0087
Did you ever figure out how you got water in the system?
All-Season Tires
I bought my 2013 with Cooper At3 & in spite of what I read about not the best stopping in wet conditions they performed fantastic on 4k mile trip pulling my 15K 5th wheel in a lot of rain, never had a problem one. They did well in the GA mud as well. The fronts cupped a little, but that wasn't the tire. I am getting ready to put Ironman AT's on next.
Ground Reference VP44,ECM,PCM,PDC plus TC lock/unlock
OK, I thought I had this, but I have only to connections that go to my alternator (see pic) and the other end of this alternator lead goes into the large loom & then breaks out by the VP44 and up to the negative side of the PDC. I also have a power lead going from the drivers side battery to the PDC. I also have a ground going from the drivers battery to the fender & one from the drivers side to the frame. (I had already changed out the cables with a kit several months back) Never had a problem except for T/C lock unlock started happening..unhooked the power from the PDC 140 amp to test.......it eliminated the T/C problem.......changed the alternator out, put on a additional ground from the PCM to passenger battery. Worked for a while...and now I am opened up the loom seperated out the grounds & I am not sure about what to do with the PDC negative. I would think big awg ground, but why isn't my truck fried? again no other problems or codes..Ok I figured it out. It looks like a ground cable, but it is NOT..If I had kept reading which I did..I did run a extra ground battery to battery. And yes I triple checked where it runs to..
W-T ground wire mod - Simplified
As Always thank you (and everyone) for taking the time to document, taking pictures and sharing.. .I could not afford this truck without the information I have gained from this forum & that's a fact. So about this modification, I am not sure where I missed it, so just to clarify, the alternator lead going across the motor to the PDC is eliminated. In it's place we will have: A. Alternator charge lead from the alternator to passenger battery.. B. A power lead from the drivers side battery to the PDC. (The grounds I believe I have correct & will be done with all in about an hour) Electrical is my Achilles heel .......LOL I ON EDIT; once the B+ charge wire from the alternator is moved the shorter distance to the passenger battery, a great solution, but you lose temperature battery sensing with the sensor still on the drivers battery. You can either move the sensor over to the other battery, with some modification, or run more parallel cables battery to battery. It will need two more heavy cable negative to negative and one more heavy positive to positive. My solution is to run one longer B+ charging cable to the drivers side battery. Without the battery temperature sensing feature on an old battery that develops a shorted cell will cause the PCM to keep charging the battery at full tilt. The alternator will get smokin' hot and can cause damage. Luckily I got home before any real damage to the PCM or other possibility of a fire. I popped the hood , knowing something was wrong and the alternator was so hot it was smokin. You couldn't touch it. I replaced it and both batteries and all was fine. I did notice where the shrink tubing on the charge wire started to melt as well. I'm glad I caught it when I did. AN IMPORTANT UPDATE: A recent conversation with Billy (W-T) he spoke about the absolute importance of properly paralleling both batteries by adding one more positive to positive cable and two more negative to negative cables. This a much better solution than all other options so that the computer will be able to temperature sense what one bank of batteries need as one battery bank. Not having a situation of charging one battery while the other has the temperature sensor. IOW, they need to be properly paralleled as one battery. This very important factor has been eliminated from W-T's original write up, so I just wanted to bring this up.
- 35 comments
- 5 reviews
- 1
Exactly what I couldn't figure out..What about charge line to the PDC? And here is the answer, Thank you...not sure how I missed it before or if that was missing, but I was really starting to scratch my head.. Thanks to all that contributed to this..You guys are the best.
2nd Gen Sub dash pictures.
Thank you for gathering up the different pics for the different angles, etc This is a real help as I am trying to get mine glued back together ..just can't see paying that $350-(partials replacement) to $800 price tag I would seriously look hard at a couple 2009-2015 dash mod's I've heard a little about before dropping $800
- 2 comments
- 1 review
New tail lights came today
I put LEDs in my license plate lights (as well brake lights) & they to help when backing up.
