Unused plugs - curiosity!
It would be easier to find Jimmy Hoffa than parts for an old HI Line system in these trucks. Good quality aftermarket accessories is the way to go.
I went through the FSM section 8W-80 CONNECTOR PIN-OUTS and came up with a few ideas. Does this truck have the "high-line" option, seat heaters upgraded factory radio?
IBMobile started following Suspension fun! , Unused plugs - curiosity! , Another NO BUS truck. It's challenging me... LOL and 7 others
Glade you found the problem. It's the simple problem that that makes a thing hard. I've had a fuse do the same thing years ago, it to drove me crazy.
EPA or CARB certified tuner
That's what I do with my Edge EZ every 2 years for the CA Smog Inspection. It takes 5-10 minuets. When I bought the EZ it was legal here and no inspections were required. Then every Ram diesel pickup truck 1998.5 and up was to be inspected and the Edge EZ became a noncompliant device. Ah, states laws, one day your good to go and the next day you're felon.
High output alternator, bypass alternator fuse?
The150 AMP alternator fuse holder is mounted on the outside lip of the right battery tray. I had to drill a hole through the fuse holder to mount it.
What type of rotor set up is this?
Try applying heat to stubborn bolts/nuts next time. Mapp or acetylene gas torch will do it.
Seat belt light
You are right about the retractor having the switch in it. From the FSM: "A seat belt switch is integral to the driver side front seat belt retractor unit."
Dead Dash - Flashing Odo - Alternator Not Charging
The "W-T ground wire mod". This moves ECM, VP and grid heater grounds from the left battery to the right battery.
Have you seen this article about the PCM grounds? 24 Valve 2nd Generation - Electrical PCM Ground Splice Repair
I second what @Tractorman recommends. last October, while on a trip to the Portland area, my alternator shorted to ground. The short blew the 150-amp fuse, similar to the photo above. I had installed it after doing the "W-T" modification. With out that fuse and the properly gauged wire there could have been a catastrophic fire under the hood.
2002 Dodge Ram 3500 24v manual- Issues - Need Help Please!
That is caused by high resistance by either open circuit or a bad ground. OHM test those circuits for a problem it might help you with the other problems.
10-4 App
Maybe a different blend. Found this online: "Biodiesel generally yields lower fuel mileage than conventional diesel, with a roughly 10% decrease in efficiency for pure biodiesel (B100) due to lower energy density ( content). However, common blends like B20 (20% biodiesel) typically show negligible differences in performance or mileage compared to conventional diesel."
Suspension fun!
What's the pin weight, empty/gross, on the truck's rear axle? Is that 16k lbs. empty or gross?
New Kicker Speakers for Beast!
Same speakers I put in my truck three years ago. They sound all right. My son says I should put a small base thumper under the seat so that I can "feel the music". Just what I need to go deaf faster.
WOLFBOX G850 PRO 4K Mirror Dash Cam
Nice dash cam. I have a dash cam in all of my vehicles, not as nice as yours but it's cheap additional accident insurance for when the other driver says, "it's not my fault". Case in point when a truck pulling a trailer ran the trailer into my right front fender. He was giving me a song and dance about it until I said " do you see that camera in the windshield? It's recording everything". He then said, "I guess you got me". His insurance company was giving me a bad time about paying the claim. I told them to grab a box of popcorn and watch the video on You Tube. They paid up. https://www.youtube.com/watch?v=5mTHYzV5IT8
