Andyba20
Quarterly Subscription
  1. Looking back on the thread, Mike mentioned this a few days ago “Remember Bosch stock injectors are NOT made as a set. You could have low end of 293 bar you the high end of 327 bar. This can affect idle performance. Ihigh suggest AGAINST using stock injectors. Buy+50 HP from any good injector shop and they are balanced as a set within 2% of flow rate” I still think it’s very likely both sets of your injectors have been mismatched. I learned this the hard way over the past year or so. Had your same stall issue after I ordered and installed a matched set from the same outfit that did Mikes injectors. Pulled them out, had 2 shops pop test them and they ranged from 290 to 330 bar (both shops showed same numbers on each injector). Pulled them back out, send them back and told them specifically what I wanted (310 bar-I believe they set them up at like 308 normally) they sent them back and I had them independently tested again and they were still off-not as much but by then I was mad. Keep in mind this was a “premium” set, not their normal budget injectors. I tossed those and went with the Mach 1 from Flux bc the owners are still directly involved with building their injectors and they’re perfect. For whatever reason my 2000 model is very sensitive to matched/balanced injectors and it sounds like yours is too. This shows my truck stalling after shifted intro reverse. On a slight hill, if the initial fuel input didn’t create enough force to back it up it would just drop and stall. The pics below show the idle RPMS from 2 different tuners. Roughly 750.IMG_6135.mov IMG_6162.mov
  2. I still think it’s your injectors @jeremyf9806 I don’t trust any of the mainstream builders anymore, there is almost no quality control-quality control doesn’t fit their business model. I’d either have a trusted local shop set up some oem Bosch injectors, or order some Mach 1’s from Flux Diesel.
  3. Andyba20 replied to Mace's topic in Introductions
    Pretty slick @Mace keep it going.
  4. I hope that fixed it, but don’t be discouraged if it comes back. Sometimes disconnecting the batteries can temporarily clear up issues when the capacitors drain. If it comes back make sure you do the full WT mod, get great batteries, and test your alternator again.
  5. I went ahead with this and I gotta say it’s pretty awesome. Retains complete oem functionality, basically a drop in replacement, just better. GDP was really really great to work with. Again, the thing is $500, and honestly I understand why they have it priced there. It’s well designed, well thought out, robust, and they’re a for-profit company. I called them bc I wanted to see if they offered the unit without the big line kit as I already have the 1/2” lines and fittings. They don’t, but they were really cool and let me order each individual part and I just bolted them together myself. That cut the cost to a more reasonable $300 or so. I told them they should offer this option, but for now I think they just want to offer a drop in replacement. It’s worth calling and asking though if you’re interested. Have to emphasize how professional GDP was, most of the venders we deal with on these trucks are absolute goons, but GDP earned my respect on this one.
  6. I’m sure there’s a cool way to rig up a float switch to automatically have your 12v pump come on to keep your tank filled, but the gravity feed kits from RDS seem to be pretty good. Ours is the first one, the one that fits the 99’ Fords. https://rdsaluminum.com/rds-parts.html
  7. The 98.5’s are often an oddball mismatch of some parts/designs leftover from the early 98’s…by that I mean I’m not sure which fog light switch you got, but I’d say do whatever you’re most comfortable with. Honestly once you get over about 5 or 6 accessories the wiring starts to get hard to keep organized. Lots of wires, relays, fuses-and not just in the engine bay, but in the cab too. The solid state switch panels are starting to look really good to me. This for example would be the budget option-made in China https://a.co/d/6I76ama or you can go premium and American made with these guys https://www.switchpros.com
  8. Why wouldn’t it retain heat from the intake manifold? It’s in the exact same spot as the OE housing? Or are you saying it will retain less heat because the filter isn’t contained inside a thicker housing?
  9. I decided a few months ago I am tired of messing with the factory fuel filter housing. It’s not easy to remove the lines when I need to, and even with new hardware it still leaks at the drain valve sometimes. I have a large auxiliary trans cooler/fan mounted on the frame rail as well as the Raptor 4G so I don’t really have room for a rail mounted filter. While weighing my options I came across this from GDP https://www.glacierdieselpower.com/collections/fuel-filter-systems-vehicle-specific/products/glacier-diesel-power-1998-5-2002-dodge-ram-5-9-cummins-mk-7-big-line-kitheated-mk79852-blkh It is pricey, but it retains use of the OE WIF plug and the fuel heater. It mounts in the factory location, uses a spin on 7 micron filter, and moves the outlet from the bottom to the top side of the filter. Probably gonna go with it, can’t find any flaws in their design-can you?
  10. So I have a spare filter base for a 04.5-12 Severe Duty Filter Kit from Geno’s. It has a fuel heater and WIF sensor built it with connector for each. Is there any reason I couldn’t use this on my 2000? In my mind I could just replace the factory heater and wif plugs with whatever matches the Geno’s kit and run the extended wiring. Of course I’d be mounting it to the frame rail.
  11. I’d imagine those ends were cold welded using a commercial grade crimping machine. I believe that’s the standard for pretty much every military, marine, aviation, and automotive compliance organization in the country today.
  12. I have the high idle enabled from my old Smarty S03, it works great in 6 cyl and 3 cyl which I just experienced for the first time when it got -5 here in TN a few weeks ago. To @Tractorman’s point it does sound awful in 3 cyl but I was expecting it. I sold the Smarty for an Adrenaline, but I liked the Smarty just fine and it gets way too much hate in my opinion. I never had any trouble with it and it was simple. Double-try posting in a local Facebook group, it wouldn’t take 10 minutes for somebody to let you use their Smarty.
  13. Has anyone had any experience with this company? Seems like a viable alternative to swapping an axle or buying another truck. No, it won’t legally change the tow rating but would increase stability when towing at the very least. https://www.southwestwheel.com/c-10-single-to-dual-wheel-adapters.aspx
  14. *update* the ground wire of the wiring harness for the Raptor (relay harness) had slipped down behind the radiator. Got the fixed, still showing a MAP sensor code. Cleared it but came back.
