Low Smoke Passing Power
VCO are cleaner but limited in power.
SAC are more powerful but can prove to be rather dirty and smokey.
I say tap the pump first. Because no matter what setting you using you still limited to level 1 fuel wise till you tap the wire. So all you doing is modify the timing and what small amount of the CAN Bus signal that it. Once you tap that pump you'll jump upwards of 120 HP out of just the module then you'll need way less injectors. Just ask JAG1 about the trip to McCall. In 4th gear my truck will spin the tires loose on dry pavement. All I got is Edge Comp (5x3), stock HX35W turbo and +50HP injectors.
Your not saving yourself anything by not tapping your pump. You can turn that edge up to level 5x5 and your only getting about 65 hp because your actually giving it no more over than an edge ez would. Tap the pump and go from there, you will probably want larger injectors but you might be surprised.
  • 4 weeks later...
  • 4 weeks later...
