Time for a power steering flush
http://www.dennysdriveshaft.com/p2077_spicer_708047_ball_joint_set_for_2000_and_newer_dodge_ram_25.html#photo
That's a link for 01-02 rams, but dennys has the ones for 99s I believe.
other parts you may want to replace while things are apart
-axle washer and nut
-axle u-joint
-unit bearing if it's bad
http://www.dennysdriveshaft.com/p478_spicer_spl55_3x_universal_joint_dana_60_4x4_front_axle_u_joi.html
-if I were you, I would replace that front axle u-joint even it doesn't need it...I'm kicking myself now for not doing it when I dove into the front end this winter
