Big Line Kit
Or just not adjusted properly. My point was at 21psi the seal isn't going to blow out, and I need to run that high of pressure to keep decent WOT pressures. Next on the list (after twins) is a fass 150 and modified Vulcan liberty fuel module.
I need a reliable system for the trip in late spring.
3/8 lines running from the tank to the stock filter assembly.
Stock line from filter to VP.
Pressure drop from idle to WOT is 11psi or more. (21 to 10 or less)
I haven't replaced it because when I put a big boy pump on I'll run all 1/2in lines from tank to VP and use the space from the stock filter to run a breather bottle.
what is a breather bottle?
I'll run the breather off the front of the engine into a bottle with a filter on the top so it'll quit spitting on my diff. I don't mind the 12v tappet cover dripping every now and then, but I like to keep the front clean.
