So I noticed yesterday that I had a decent little puddle of oil under my motor yesterday when I went outside.  Nothing huge, but more than the nothing I usually see.  I'm having a hard time figuring what it might be though.  I kind of figured it was the vacuum pump leaking, but I don't see an actual leak from the junction point between the power steering and vacuum pump.  It might be coming from further forward.  I'm getting most of the leakage down onto my pitman arm, then blowing over my front suspension etc.
What I've Noticed:
-Oil dripping down the driver's side near the frontish part of the motor, definitely somewhere behind the timing cover.  Most drips down onto the pitman arm.
-No leaking evident from tappet cover, and I think I can see it pretty good.
-Power steering is down a little (between hot and add, when the engine is hot), but that's not surprising, as I know the hydroboost is leaking a tiny bit at the brake pedal, but I suppose it could be power steering fluid.
-Oil might be down a hair (maybe half a quart), but it could be just from being on uneven ground.
My Question:
Is there anything I can do to pinpoint the leak?  Anything I should be doing that might make it more evident?  Maybe have someone turn the wheel while I'm under there with it running?
  • Replies 14
  • Views 2k
Vp44 can leak if it isn't tight on the cover.
I would check the 4 bolts that hold the vp44 on.
It amazes me how much the air will blow the oil around under the hood. My tappet cover gasket failed and it looked like everything was leaking. The part f it behind the VP is hard to see. Mine was visible elsewhere which made it easier to diagnose.If you can clean it up and dry it off good you would have a better chance of seeing the source.
Nates,
There are a couple places for the vacuum pump to leak oil.  1) Gasket to front timing cover (least likely) 2) rear seal where the drive coupling exits to drive the power steering pump. 3) oil feed line.
You will just have to clean the area well and use mirrors to see where it is coming from.  Hope you find it!   http://www.fixinrams.com/ has some great pictures of the vacuum pump apart so you might be able to see better what you are looking at/for.
HTH
Hag
Turns out it was the injection pump.  Just had a chance to check it out.  Doesn't move a whole ton, but enough.  Think I need to worry about the gear/keyway or just cinch the pump up to the cover?
Thanks
cinch the pump and keep going.
My key was no worse for wear when this happened to me.
looks like I'm missing the bottom stud too.  Red Loctite to screw into the front cover?
umm, what locktite number?   Some of the red stuff is WAY to tough for what you want haha.
Boy do you have that right, I just sat through a 2 hour class put on by a Loctite rep for our shop earlier this week and I was mind blown at how many different products they have now, it was a class with a ton of literature on which product is the best in any application and the proper way to use them. Covered Anaerobic sealers and thread locking and retaining products.
Was a very good hands on class.
So....
What should i put on the threads where it screws into the cover?
Final count was 1 missing stud w/ nut, 2 missing nuts, 1 hand tight nut holding the pump.
blue loctite 242 should be fine or really any of the loctite blue's.  These days you need to ensure you pay attention to the loc tite number.  you don't want to end up putting red loctite 272/263/268 on there lol, unless you wanna use a blow torch to get it off again.
Just pay attention to the specs of the loctite.
Edited by Me78569
Thanks.  Now i just have to track down a stud.  Local Cummins doesn't have it in stock.  Hopefully my local NAPA can scare one up.
