transmission tail seal
I think I used a screwdriver or small pry tool to get it out.  Tap the new one in with a hammer.  Finding the new one was tough, as there are like 3 different seals according to the parts guy at O'Reilly.  Rock Auto failed me on that one.
Part # lookup tool
They do make a tool specifically for pulling seals, however, I do as CSM said and use a screwdriver. I would recommend using a socket that fits just inside the outside diameter of the seal to hammer on so you don't ding it up and grease the seal so it slides in easier. I also recommend greasing the inside of the seal so the shaft doesn't tear up the seal before gear oil gets to it.
Edited by eddielee
1 hour ago, eddielee said:
Part # lookup tool
Good points.  I used a bit of ATF and put in there... But on my case, the seal is huge and I don't have a 2.1 or whatever it is socket!
Edited by CSM
Thank for the parts list that sure is help full. Little bit of a pain flipping though 470 some pages to find it. It also shows 3 seals so not sure which one to get. Mine shouldn't be hard to get out its already about inch and a half  back off.
