4wd System Refresh np241DHD rebuild.
- Replies 70
- Views 11.6k
Me78569 31 posts
TFaoro 11 posts
Mopar1973Man 10 posts
notlimah 6 posts
Big thanks to dynamic and his advice The main shaft position is set by the rear main bearing in the transfer case.
I honestly have no idea. I do some cross checking on the parts. Tyler and i should be a
A press is the best tool for changing the hanger bearing and Then spin balance it afterwards. Having worked at a shop with a driveline spin balancer it is amazing how little weight it takes to cause a
Well the time has come to tear into my NP241DHD, I just bought an overhaul kit, ( seals and bearings only). I will be dropping the transfer case at some point next week / weekend.
Issues are I have a random grinding when I hit bumps, either in the CAD system or in the transfer case. Pulling the stick back to 4x4 makes the noise go away, but I not longer have a working vacuum actuator either so I don't know if it CAD is to blame as I really doubt it is able to move the collar.
I also have no ability to go into N or 4l in the transfer case. It literally hits a wall trying to push from 2wd into N, so I am GUESSING that the shifter collar inside is FUBAR, but I won't know until I tear it apart.
I am gonna go to the junkyard on friday and get a replacement CAD actuator and new vacuum lines as I can't even look at them without them busting / cracking.
Gonna take a bunch of pictures as I go.
Also as a side note, I finally decided to figure out exactly what axle is under my truck. It is a 610428-4 so a 3500 1994 front axle. nice to know rather than guessing.
