Governor solenoid choices
The GM conversion is no better than the Borg Warner HD, but it is 3x as expensive. The GM conversion uses a late-model 4L60E  pressure control solenoid, which often become troublesome when they get up there in mileage.I build a lot of 4L60E's that are on my bench because of this solenoid...
The BD kit (TCS also sells it) simply uses an early metal transducer (which tend to be a bit more robust) and supply a small harness that converts the wiring to work with the late-model PCM. I have never used one, so I don't know the specifics on their little wire harness.
I use and highly recommend the Borg Warner HD and an OEM or Borg Warner transducer...
17 hours ago, Jbolduc said:
I ended up going with these
Those are the ones... Decent price, too. We sell them for a couple of bucks cheaper, but this is a good price, too.
  • Like 4
