Anyone experience an oil leak after changing out your vp44?
it seems to be on the driver side front of the engine but the fan is blowing it everywhere. I've used degreaser and a pressure washer on the motor/underneath and no luck.
Seems like mose of it is ontop of the power steering pump but I've also seen a drip behind the harmonic balancer (running along side the motor and dropping there I
believe).
anyone experience anything similar it's frustrating me a whole bunch
  • Replies 13
  • Views 3.9k
  • Mopar1973Man
    As the vacuum pump creates the vacuum it vents the air into the gear case. So if you have a vacuum leak then the vacuum pump turns into a small air compressor and pumping air into the gear case increa
You can have an oil leak if you don't tighten the vp44 to the case.  Otherwise the common puke bottle could be to blame. I would guess the vp44 to gear case is leaking though.
just remembering I have a vacuum line that is broken  (one that runs across the top of the firewall. Is it possible for this to cause excessive crankcase pressure?
That is possible. I can't confirm for sure, but I have read that the vacuum pump vents into the crankcase.
Vacuum leaks will increase crank pressure, thus blowing more oil out of the breather.
Could you please explain it better for me, I thought vacuum pump was an external unit and has nothing to do with the engine only for accessories. Funny thing is I just discovered a vacuum leak on my truck, next to firewall by the check valve had old soft rubber hose. It rubbed through where it touches the dipstick.
As the vacuum pump creates the vacuum it vents the air into the gear case. So if you have a vacuum leak then the vacuum pump turns into a small air compressor and pumping air into the gear case increasing the blow by gases and possibly adding blowing oil to the list too. So when the vacuum system is leak free there is no air pumped into the gear case. Also the engine oil is fed into the vacuum pump it increase sealing of the sliding vanes that oil drains back into the gear case as well. It's slung off the gear as well lubing the gears in the case.
Fixed two vacuum leaks. Leak hasn't stopped. I'm out of ideas
make sure the vp44 is tight to the time case.  Happened to me.  the vp44 wasn't fully seated.
That makes perfect sense, I can't belive I forgot that vanes are lubricated by oil and that's why you have to clean them when doing a rebuilt on vacuum pump. For some reason I was thinking it was just creating vacuum all in its own and had nothing to do with engine. I suppose them vanes would wear out pretty quick if not lubed.
The VP ties directly into the timing gears where loads of oil is moving about.  In order to keep the oil from escaping the VP has an o-ring which seals the hole it fits in.  If that o-ring is damaged then oil will obviously leak all over.  Since this leak happened after that replacement, I'd say this could be the problem. :thumbup2:
Edited by KATOOM
Going to double check if everything is tight this evening and if It is I guess I'll remove the pump again and go from there to see if I can find anything.
I know I definitely didn't install one but I'm almost positive that the pump had one when I  received it
