Drum brake adjustment
I`m going to be doing some work on the old GMC 2500 today. It has drums on the rear and I would like to check the adjustment.... In the past I have always dialed them in to the point of installing the drum and not being able to feel any friction.. My understanding was that should self adjust any time you back up with the brake applied??
I`m just looking for input from anyone who might have a different theory..
  • Replies 25
  • Views 72.1k
  • I've always made sure everything is clean and freely moving and properly fitting.  Then adjust out the star so that the drum barely slips over the shoes.  Then adjust the star out some more so that wh
  • Today I adjusted the shoes all the way out, then backed them down about half a turn. went for a test drive and no real difference... I think I was already pretty close. I decided to try @Mopar197
  • 01cummins4ever
    01cummins4ever
    So I finally got some time and crawled under the Dodge and popped the lever off the load adjustment valve. I raised it all the way up and it actually fell back to the 11:00 position so I just tied it
On 8/28/2016 at 8:33 AM, 01cummins4ever said:
that's the next step is just to take the valve off completely, and splice the lines together.
I agree just another example of over engineering
Unfortunately the brake line from the axle to the valve doesn't have the normal brake line fittings so I believe you have to get that specific replacement line and cant use any universal line.
Yep, I havnt looked into it to much but maybe find a truck similar in the bone yard that doesn't have the valve and take the brake line off
  • 3 years later...
Self adjusters work to keep the shoes in adjustment. Put the drum on, pop the rubber cover off the back and adjust them with a screw driver or whatnot.
  • 3 weeks later...
On 6/19/2020 at 10:44 PM, worldclass1 said:
Self adjusters work to keep the shoes in adjustment. Put the drum on, pop the rubber cover off the back and adjust them with a screw driver or whatnot.where am i 192.168.8.1 192.168.100.1
it says i am expired member what does it mean.
Edited by worldclass1
To be a full and use all that is available here you have to subscribe. Go to the subscriptions page and it is all explained and you can join at whatever level you wish. It is quite reasonable for what you get.
