Tapping noise
It isnt good.  Rod bearing or injector is typical for a tap.  I dont recall seeing any lifter issues.  You might get a clue by sending an oil sample in and seeing whats high...
Edited by CSM
I vote lash as well otherwise get a northern tool 5 dollar stethoscope to help isolate location block or head.....:thumb1:
Also I'd say change the oil but put cheese cloth over the pan to filter oil through it can get messy so plan accordingly once drained pull cloth and inspect with daylight followed by the brightest light you have access to...  you likely won't see anything but with the light if you have issues the cloth will likely glint or glare from shiny metal if you see that jar up some drain oil and send it out for analysis.... best of luck
Edited by WiscoRedkneck
Steven,
You may want to double check for an exhaust leak.  The ISB just seems to love cracking an exhaust manifold and/or losing an exhaust stud near #6 cylinder.    Rattle Monster happens to have both at the moment, and over the weekend buddies had trucks over and of the other three in my driveway, 2 were missing exhaust studs.
Hope it is something simple like that!
Hag
