Engine/ECM troubles
Truck started acting up last weekend and had codes for APPS. I reset the APPS, which is about a year old Timbo APPS, and ran fine. This evening coming home from work truck was cutting out(dead pedal) Cruise control wouldn't even work and kept kicking off on its own. Got it home thankfully and got codes of 0562, 0575, 0342, 0112, 1488, 0606, 1295, 0237. Have Edge JWA truck is 2001 with 6spd and 273k on clock. Am I lookin and a new ECM? Any suggestions or where to start.
Sounds like an ECM to me, but I would go through this first.
Return the truck back to stock electrically, pull out the edge etc.
Get some dielectric grease and clean and apply EVERY plug under the hood with it.  Cycle every plug a few times to ensure good connections.
Clean EVERY ground connection in the engine bay.
Well I checked alternator seems to be within specs. After leaving batteries disconnected all night and removing the edge jwa there's no CEL on anymore. Letting it warm up and take a drive and see what happens. Could the edge have something to do with the issues?
Didn't even make it out of driveway CEL came on cruise indicator was coming off and on, on its own and dead pedal. Safe to assume the ECM is shot?
3 minutes ago, Hawkez said:
What do you mean by within specs?  Did you just check the vDC?  Did you also check for vAC?
Checked for vAC as well
