- Replies 99
- Views 14k
CLAUS1 35 posts
Me78569 21 posts
Dieselfuture 10 posts
notlimah 9 posts
Firstly can you fill out your sig so we know what you have on your truck? I can't rememeber are you still running a stock turbo??? ( please tell you aren't) Next you really should unstack
Hard to know what you know by " no power" a stock 2nd gen truck is a real dog. 235 hp trying to pull 7000#. Do you have 150 injectors as well? or where you asking in regards to upgradin
I just put the Fuel Gage sending unit on 5 minutes ago, I'm going to drive it now. It sits at 19 idle
Need some help here! 2001 Dodge Ram 3500 5.9 cummins diesel. Air Dog Original,fuel sump kit, New VP44, A&E Air Box Kit. Smarty S03 stacked with Edge Juice W/Att. All of a sudden the truck start to like basically cut off all horsepower if i stand on it, so i have to back out of it and it takes off again. I took smarty off and edge juice to see what the truck does. With all programmers off the truck it has basically NO Power ever, feelings like im pulling a train! I took truck to dealership they flashed both ecm,pcm back to stock and uploaded all updates including set my 35 in tire size. Truck Did have a little bit of power but not really driveable. Have code po501 and thats it besides po1693. Please help send me in a direction that will solve this issue.
Edited by CSM
