Ok so on my 99 cummins there is nothing that says what fluid should be in my p/s pump. Can't find my owners manual. So I looked on here at downloads and they don't give a fluid spec. So next thing was google. Some people are using Lucas or atf +4 or whatever. I have a bottle of plain ol valvoline p/s fluid but is that right? Thanks.
  • Replies 17
  • Views 29.5k
  • 2002 and older: MOPAR  MS 5931 or equivalent 2003 and newer: MOPAR ATF +4 type 9602 or equivalent
  • 01cummins4ever
    01cummins4ever
    Nothing but straight off the shelf power steering fluid, Stay away from atf or Hyd. oil.
  • Mopar1973Man
    I've been using Dextron ATF in my transfer case for years now. No issues to date.
PS for me. Just as available ATF and I have 395k on the oe pump. It must like it.
I don't see a problem with it, it states that it replaces mopar ms 5391, It does not have to be brand specific
I just found it was weird there saying 5931 bottle is saying 5391. Online specs for the bottle is saying 5931 haha crazy.
17 hours ago, 01cummins4ever said:
Yep, probably misprint, I would think 5931 is correct number,
I agree just kinda funny to me by the way. Does anyone know the correct fluid for the transfer case. I've been reading +4 or dexron ll. Thanks
Transfer case: NV231HD, NV241LD, NV241HD, fluid ATF+4 type 9602,  fill to bottom edge of fill plug,
drain and fill plugs tightening torque 30-40ft-lb
Dextron III in my transfer case and Redline PS fluid in the PS pump.  I'm a fan of running synthetic PS fluid because if the heat generated in the hydro-assist system.  Its gets pretty hot during the summer and the fluid capacity is pretty small for all the work that system does.  Just my opinion.....  :thumbup2:
