- Replies 9
- Views 9.1k
Popular Days
It's curable as long as the truck has no problems otherwise it's and call Mike for the ten thousandth time. Poor guy never gets a break. Reasons I been like that..... Work tru
I THINK they are a M10x1.5. if not, they are probably a coarse thread M8. If you have an ace hardware or home depot anywhere near, take one of the nuts and head to the metric aisle. From there y
I'd go to Napa with the old stud. There they will be able to measure it (pitch, diameter and length) and either have one close in size, same pitch and diameter but slightly longer would work, or orde
Hi all,
I have searched and searched for this info and I don't believe I have the answer. I need help.
Short version: I need to replace stud and flange nut that hold my VP44 on. What sizes are they? How do I find them?
Long version:
I have been slower than molasses working on my VP44 replacement as I am not dependent on my truck for a living any longer. I went out to try and finish up. I lost one of the flange nuts that hold the pump to the mount. No big deal, I'll take an original to the parts store and get another. Well, it has turned into an ordeal. They tried it and said it was a 3/8" x 16tpi. Ok, order in 2, please. They come. I try it...it feels way too tight and I don't want to mess it up. I run into town to search for something different. Parts store has a crazy long line and 1 man working. So I grab the cable with all the example pieces to try your nuts on...found the one the original worked on. 3/8"x16tpi. Put the new one on it, and it worked too. Decided that I must have just been overly cautious, thus costing me an hour.
I drive back home and try to crank it on, deciding the old stud must be a little too rusty and the new is catching. I did spritz it with some WD-40 first. Nope...not the right size. I try to back it off and the stud backs off. I take it out to disassemble and figure this out. I cannot get the nut off. Doh!
All that to get to here. I thought I found the right part list here http://www.factorychryslerparts.com/showAssembly.aspx?ukey_assembly=666948&ukey_make=1062&ukey_model=15505&modelYear=1999&ukey_category=20311 as this is a diagram of the VP44 and mounting gear. According to it, that hex flange nut is a M10 x 1.5. I called the parts store here and they could get one like that, but the head was 13mm. My OEM nut takes a 15mm.
I can't believe how hard it is to find this information. If I am missing an obvious resource, please direct me. My downloaded copy of the parts look-up list isn't working. And my donation status shows at zero even though I have donated before. I'll go use the look up and add the part numbers I find later.
Thanks for any help.
That should be a flange nut at the #1 arrow. And the stud that nut goes on....these are the two things I buggered up.
Thanks for the help!
I found the look up tool. Duh.
It ways the flange nut is a M10 x 1.5. But there are no specs for the stud. I know the one end needs to match that, but not sure if it is the same specs, the length, etc. I'm going through O'Reilly's and may look at Auto Zone to see what they have with those sizes that look close. The tool has part num 0476150 for the stud, but that doesn't return anything for me in Google or on O'reilly's site.
But I know someone already has this information. Any help appreciated. I want my truck back.
Edited by jamman
