2001 idling high, rough idle
Roger that, I've got batteries disconnected now, gonna do a reset and then check the voltage again. It still seems to be idling a little high and rough but definitely better. I just cleaned all of my grounds while I had the free time.
so should I be in the market for a new alternator? Any suggestions? I'd like to up the amperage output a little if possible without spending way too much money
33 minutes ago, Me78569 said:
2. @Mopar1973Man whats the load ac limit?
0.01 to 0.03 is normal
0.05 is marginal
0.1 is a fail
43 minutes ago, CumminsHokie said:
3.) what's to say my tc won't start locking and unlocking really badly when I pull off the noise isolator?
Because your alternator is producing too much AC noise. Take the alternator off and have it tested.
44 minutes ago, CumminsHokie said:
1.) what would cause my apps voltage at idle to randomly increase to .93?
Idle voltage doesn't matter. What matter that the ECM sees the IVS (Idle Validation Switch) grounded for idle. Idle voltage won't matter as long as the IVS switch for idle is selected. Then its strictly up to the ECM to control idle.
Too many clean the wrong grounds...
If you want to test the APPS for that problem just unplug it. ECM will use only idle software.
I cleaned my battery terminals as a part of cleaning all the grounds. Is that enough to satisfy g115 or should I get spray the plugs with contact cleaner?
im glad I joined this forum and I really appreciate all of the help!
@Mopar1973Man you've done a write up on testing all of the apps connections haven't you?
I would use some dielectric grease in the plug and cycle them 3 times. That's it.
This isn't exactly but it should give you so info...
I think I was thinking of testing the idle validation switches. I reread that article and now it doesn't seem as applicable.
Anyone have any suggestions on a good alternator? Or is it more along the lines of just don't buy a reman?
I'd stay away from alternators from your local parts stores,   when I was having problems with mine before  rebuilding it, I bought one online from one of mopar discount sites. Ran it for few weeks till I rebuilt my old alternator.  Now I have a spare. And I am not sure if you want to up amprige too much as it may create additional problems.
How's the process of rebuilding an alternator? Need any special tools? Is it good enough to rebuild the one I bought from the local parts store?
rebuilt or new can come with to much AC voltage. Have it tested while in the store. While .1 ac voltage is a fail it may not be when the grids are cycling. Someone correct me if I am wrong on that. I always thought the test should be run at idle with all accessories off. I have read of folks that have added the extra ground on the apps but seems more of a band aid like the noise isolator.
 Was your engine running at 17% or the apps just showing 17%?
Rebuilding isn't too hard. The worst part is finding a rebuild kit that has quality diodes. The only thing that might be a bit tough is pressing the bearing on the shaft.
Roger that. I'll have to look into it.
Well I'm not sure to be honest. I believe that the engine idling high was due to the apps being at 17% but I can't say for sure that the engine rpm increase was proportional to the 17% or the increased apps voltage of about 0.9xx volts.
I didn't think it was that hard to rebuildit, like Mike said getting good parts is pat of the battle. I got my parts from local rebuilder. Getting old bearings off was a bit harder then putting new ones on as there's hardly any room to get under bearing to pull it off. I ended up putting old bearings in a vice till outer race cracked and fell off and used a small cutoff tool to cut through inner race, and being careful not to cut into shaft. Also make sure you get new Armature and brushes as they can also create additional ac noise. If you got extra cash just by one online that is new original and move on. I'm not trying to steer you from doing it yourself, just if you're time is worth money you might be ahead just buying one. This guy has some good stuff, and some vids on youtube. Check it out. http://www.fixinrams.com
Sorry I haven't been able to post much of an update, been very busy getting my Jetta tdi ready for daily driving so I can start heavily modding my truck. But first I still have issue to resolve.
Since cleaning the grounds, resetting the apps voltage, and doing an apps re learn the truck has been running much better. No "hickups" at idle, the rpms at idle have dropped some to about 850 and, whether its related to the apps sensor or cleaning the grounds, the truck just drives like a whole new truck again. So for that, I thank you guys. With that being said I noticed that my torque app was still showing 12-13% for TPS so I called Timbo. Also I did unplug the apps and was not able to notice any changes in sound or idle but did notice that Torque app now showed 0% for TPS.
We talked through the problem and he mentioned that the apps voltage is dependent on a good ground and that the ground determines the voltage. I thought it was interesting since my harness going to the apps connector had the crappy splice job with a wire going to the negative terminal of the battery. Im wondering if the connection has become compromised. I will hopefully be returning the wiring to stock this weekend assuming I can borrow a deutsch tool from work tomorrow.
If returning the wire to stock does not work I will have to move on to other things. I recently stumbled across a thread where they talked about rewiring and splicing in wires between the apps and ecm and pcm. Any input on this? is it just to fix TC locking issues or could it potentially help me with my apps issue? I have pasted a link to the document from ats below.
https://www.atsdiesel.com/PDF/120505/4th hunt 46 47 RE.pdf
Bad news... No one should ever reset APPS voltage. 99% of the time it's done wrong. APPS voltage should ALWAYS be 0.05 to 0.1 below tag voltage.
That's a sign of bad alternator with AC noise problems. If you got to relearn the APPS there is a problem. 6 years I did mine just because I replaced the batteries since then I've not done it again. The majority of the issues are caused by AC noise.
Now knowing it's a Timbo's APPS. There technically no voltage adjustment. Basically, adjust the stop pin till the voltage rises the back off till you hit bottom and loosen an extra 1/2 turn off the set screw. Timbo's does not have a voltage setting. It's an angle setting. All this does is ensure the contact or on the IDLE position of the contact.
Image result for timbos apps mopar1973man
Another thing to be aware of that if the IVS is on the throttling position then it will follow the APPS voltage. If the IVS is in the idle contact then the ECM ignores the APPS voltage and uses internal software to control idle speed. This is where people screw up attempting to adjust idle speeds or adjust to an old voltage of an old sensor. This is all wrong. Timbo's basically just need to be sure the arm return back enough to make contact on the idle contact or Idle Validation Switch (IVS).
Just had a passing thought. If you just unplug the APPS sensor and start the truck this will force the IDLE mode of the ECM. If its still idling rough then its NOT an APPS sensor issue but fuel system issue or ECM issue.
By "resetting the apps voltage" I meant adjusting the set screw until my voltage was at 0.63 V and then turning it back 1/2 a turn. I only did the apps re learn because I had just had my batteries unplugged and because I had just messed with the apps adjustment screw to change the voltage. I have my old apps sensor (i know it idled fine when I had it in) so I was thinking about just plugging that in (without installing it fully) and starting the truck to see what my torque app reads for tps.
When I did unplug the apps sensor and start the truck I said that I did not hear any change in idle but my torque app finally read 0% for tps. I wouldn't say that it's idling rough anymore but the rpms still seem higher than I remember. In park or neutral, idling, the rpms read about 850. From what I've read this is normal. I need to call timbo again but work has been hectic lately and I haven't had time. I need to make the time.
