- Replies 57
- Views 10.5k
Killer223 20 posts
AH64ID 17 posts
Mopar1973Man 12 posts
dripley 4 posts
I'd recommend SouthBend. I had their Con OFE in my '04.5 which was good for 450HP and 1000ft.lbs. IIRC. I put almost 175,000 on that clutch and it still worked like new when I traded MightyWhitey.
I'm on my second South Bend Clutch. First one lasted 140k miles roughly and had a lot of hard and heavy use towing and skidding trees.
It's a SMF and it's quiet! The O-HD is a smoother and quieter product than the OFE. I like the way it drives better and the O-HD is rated to hold 425/900 and at my last dyno I was 415/850
my 08, G56, was slowing for traffic, down to about 35 mph in 3rd. then rolled into it and the clutch slipped, let off immediately, next stop i lowered my programmer to stock from 3.
That said. i'm thinking after 160K my clutch has had enough. i DO NOT want to dual disk. and i'd like to keep it as quiet as i can.
So who to call? do i keep the DM flywheel.? or switch to the other one.
Thoughts...
