- Replies 18
- Views 3.6k
Mopar1973Man 7 posts
dripley 5 posts
Dieselfuture 5 posts
kzimmer 1 post
Popular Days
Yeah I know intake is like 0.006 to 0.015 and exhaust 0.015 to 0.030 don't quote my span I'm going from memory. My mistake I made was set the lash. Snugged the lock nut. Grabbed the torque
Trick... If the gap is a bit loose twist both the allen and the nut together tighten. If the gap is bit too snug the twist the allen loosen as you tighten the nut. You
Told my son he would drive me to the cemetery in the 02 on my last trip. He tells it better be running good or he is going to call ahead and have them dig a bigger hole. Me, just to get the last jab i
I've just learned that valve lash that is done wrong or in a hurry and I didn't verify my measurements can have impacts on performance, idling, and lope. Just a few days ago I figured I would just verify the lash and cold engine I was having issues getting feeler gauge to pass on a few cylinders. I ran the head again and verified all my measurements after torquing the lock nuts. Now after a few days my lope at idle is gone. Performance has improved slightly and even the MPG is up slightly. So I've got to admit this was my bad but I wanted to share my mistake to hopefully help other spot weird performance issues and check the basic things that might cause issue.
I remember I was in a hurry install injectors and ran the valve lash quickly and the mistake cost me a world of weird issues that never seemed to go away no matter what I did.
