- Replies 17
- Views 3.5k
Mopar1973Man 6 posts
Wild and Free 3 posts
jlbayes 3 posts
Dieselfuture 2 posts
OK... Talked to Ryn at BlueTop Steering... Great man and knows his stuff. There is one small difference between the steering boxes. It's the input shaft seal. The early version has a dust seal and pre
Just give Ryan a call at Blue top he is a stand up guy and will walk you through any questions you have. His business has really taken off and he was able to walk away from his 90k+ a year job a month
Don't worry... I'll post up the rebuild.This isn't my first steering box rodeo...
Finally after all this time the steering gearbox now just starting to leak power steering fluid. Input seal is weeping fluid and I had to top off with power steering fluid about 8 ounces worth. So I'm going to have to look into a gearbox seal kit and rebuild my box. I will not replace it with Bluetop or Readhead. Still tight steering just now starting to weep power steering fluid.
