Remember gang Edge Juice has main and sublevel tuning. So if the main level is on 3 what was the sublevel? 1-3 sublevel will defuel to a set boost pressure to clean up smoke.
SUBLEVEL
1 - 33% of stock fuel till 20 PSI boost
2 - 50% of stock fuel till 15 PSI of boost
3 - 67% of stock fuel till 10 PSI of boost
4 - Some extra fuel at low boost
5 - Full fuel at 0 PSI boost
Mike,
Those numbers can't work.
The edge on sublevel 1 , if it was %33 of stock fuel, wouldn't drive.
If the edge does pull fuel down below stock it can't be more than %15 below stock.  My truck smoked pretty good even on 5 x 1 when I datalogged it.     It was way dirtier than my quad tune which started at %85 of oem fuel at 0 psi.
@Marcus2000monster do a boost leak test.
If I could find my old Edge Comp manual which I think is long gone those where the setting listed in the manual. As for how they figured those setting and so forth I'm not sure but just reposting what my manual had. As for the new manual they don't even list the sublevels any longer. Do even explain how they work other than less responsive and most responsive.
