HE351 swap
Well I’m thinking about doin a turbo swap. I would like to have around 400 450 hp. I will be purchasing a qaud v2 before too long. I’m thinking I will do injectors too. What size would you do with the HE351 and v2? And now for the turbo... do I want the variable geometry or the cw model? I would also like an exhaust brake which I believe is built into these turbos? Has anyone else done this swap? What was your experience? Anyone please chip in with questions comments or concerns.
Mods should be in signature. Fass 150 is alsonin the books before long!
And just to clarify the truck is running well now. No issues besides the fact it snowed 6 inches yesterday and I hit the ditch! Took out the neighbors mailbox with deer guard! :mad: Thanks guys!!
  • Replies 132
  • Views 38.3k
  • 60x86 compressor wheel (same as the 7 blade super 40 wheel)   65x58 CW 12 blade turbine wheel (often called a 68x60 by Holset, thou I don’t know why)   70x60 VE 12 blade turbine wh
  • The oil feed comes from the filter housing. The drain goes into the pan at the bottom of the block.    Maybe the white box is aftermarket? Go genuine Holset.
  • Are you looking for a tow tune at 400-450 or a street tune at 400-450 and 350-375 for towing?   The reason I ask is the HE351CW is about a 350-375 rwhp turbo for towing at altitude and reaso
the cw doesnt have an eb, the ve does.  You need a standalone contoller for the ve to work.
for 400 hp towing 7 x .010 for the cw alittle bigger for ve ask the exhaust side can control upper end fueling better.
For you I would do a cw, I dont think the complexity of the ve install/controll  is a good thing for you.
Is the controller for the brake? What is involved in the controller?
Just got done reading that article lol! Very good info. But it is defiantly over my head! :whistle:
Isn’t there another turbo from maybe a 6.7 cummins that has the eb?
Thought it was from a late 5.9? Boy flip I have much to learn before this becomes reality! Lol. So unless I do the ve and controller I will have to buy a aftermarket exhaust brake?
no a he351ve is on all 6.7 cummins.  Late 6.7 use a he300ve, but it is the same turbo with the same controller.
Yes you will need an aftermarket EB.
Please check the articles section. As with a lot things there should be an article for both in the 2nd gen > engine > air & exhaust
call @dieselautopower
However I would guess if you can't piece it together yourself you are better off getting a drop in turbo.  the cost of buying a kit will likely get you really close to the cost of an sxe
Edited by Me78569
I am sure I can piece it together I just thought that if there were a kit it would be nice. I’m the article that @TFaoro wrote is that everything I’ll need?
1 minute ago, Me78569 said:
If you dont build your own charge pipe, or go cheap wih a 45* bend to adapt the stock to work.
Stainless diesel offers this http://www.stainlessdiesel.com/index.php?route=product/product&product_id=176  I used that for my VE swap.  DAP sells a silicon piece that you can use,
Or you can build your own.
I’m not a pro fabricator so I’ll prob buy that one. What else do I need to know?
