- Replies 132
- Views 28.8k
Marcus2000monster 63 posts
Me78569 32 posts
AH64ID 13 posts
trreed 9 posts
60x86 compressor wheel (same as the 7 blade super 40 wheel) 65x58 CW 12 blade turbine wheel (often called a 68x60 by Holset, thou I don’t know why) 70x60 VE 12 blade turbine wh
The oil feed comes from the filter housing. The drain goes into the pan at the bottom of the block. Maybe the white box is aftermarket? Go genuine Holset.
Are you looking for a tow tune at 400-450 or a street tune at 400-450 and 350-375 for towing? The reason I ask is the HE351CW is about a 350-375 rwhp turbo for towing at altitude and reaso
Well I’m thinking about doin a turbo swap. I would like to have around 400 450 hp. I will be purchasing a qaud v2 before too long. I’m thinking I will do injectors too. What size would you do with the HE351 and v2? And now for the turbo... do I want the variable geometry or the cw model? I would also like an exhaust brake which I believe is built into these turbos? Has anyone else done this swap? What was your experience? Anyone please chip in with questions comments or concerns.
Mods should be in signature. Fass 150 is alsonin the books before long!
And just to clarify the truck is running well now. No issues besides the fact it snowed 6 inches yesterday and I hit the ditch! Took out the neighbors mailbox with deer guard!
Thanks guys!!
