- Replies 44
- Views 12.3k
Dieselfuture 14 posts
Me78569 13 posts
Quadzilla Power 9 posts
NmPunk 3 posts
If you built tunes on the 2.5 profile (the standard V2 Dodge 1998-2002 v2.5) profile then they should still be there when you update the vehicle profile to version 2.7. If you are moving from the Quad
Unfortunately there isn't a real good way to fix that other than removing the data. If you have access to your tunes now you can export them all to yourself, delete the app, redownload (or just clear
Did someone say V3?? We're waiting patiently Nick...
Talked with @Quadzilla Power today about the 2.7 beta -> final move. We both decided that the boost offset feature was causing more trouble than it was worth. we have reverted how the late model trucks read boost to using the 13 psi offset. The way the truck drives is perfectly fine if idle psi is 0, 1, or 2 psi. It is annoying but trying to solve the issue just complicates things more than most are willing to work with.
the mpg trip and mpg meter + improved handoff stayed in place.
I know I have said this a few times, but I think V2 tuning is wrapped up and done done. Now onto V3
kidding of course.
Edited by Me78569
