- Replies 8
- Views 2.1k
dripley 3 posts
gassernomore 2 posts
skyhigh4by 2 posts
Mopar1973Man 1 post
Popular Days
Do you have anyway to check your fuel pressure? Weak fuel pressure can kill the VP, hence the 216 code. Dead pedal and hard starts can go hand in hand with that also. If you go the articles section, 2
14 psi is minimum. Anything lower than that contributes to the death of a vp. My truck runs at 18 psi and 15 psi at WOT.
Ive been chasing down problems with this new to me 98 24v and just got a pretty big indicator I think. First I diagnosed alternator AC problems causing TC lock/unlock issues, and then narrowed down my TC not unlocking to a couple things but now I was just out for a drive, stopped at a buddies house and we figured it was idling a little high 900rpm(ish) and the CEL kicked on while I was there. I was going to try an APPS reset when I got home but on my way home cruising down the highway my throttle pedal went dead and I had to be towed home. Pulled the codes and got P0121, P0122, P0216, P0234, and of course a P1693 to go with it all. I know what the definition of each code is but what is the actual underlying message here? Truck has 100k miles and is all original besides alternator and lift pump. Generally the truck drives fine and seems like it runs pretty good but sometimes it has been hard starting lately and I think Ive notice very brief dead pedal a couple times before. Before I just got buy an IP is there anything else I should be checking?
