Bobbing of idle with larger injectors fix
The bobbing when i come off throttle and truck is trying to idle is getting worse with the increased temperature outside and when i have my ac on when it revs up it blows quite a bit of smoke out. It stops when i get to a speed less than about 10mph. Question is could i break the vss line momentarily or ground it out to trick the ecm that i stopped and return to a normal idle?
ya when i have my ac on it causes it to bog down enough it pours out smoke trying to recover and it gets real old as im coasting to a stop im puffing a cloud of smoke out every few seconds or i can kill the ac and its not as exaggerated. im thinking about a momentary disconnect activated by the clutch.
