- Replies 19
- Views 8k
Mopar1973Man 4 posts
Dieselfuture 4 posts
dripley 3 posts
striegel.t 2 posts
I look at it this way there is no reason to go messing with $250 dollar unit bearings attempting to make them better. My bearings lasted 150k miles each time. So if you look at this way you can go aro
This pulsation seems more rapid than the rotors a turning. Kind of odd for warped rotors.
FWIW, I have been able to lock up the breaks on my truck since it was new. the ABS just pisses me off, because it relieves pressure for a second, then if you keep pushing on the brakes it locks them
All
I seem to be having the common problem of my ABS and Brake light on my dash being on, so I am following the document below, and it seems that my 4WD light does not come on when I shift into 4WD (been like this for a while though), so I replaced the switch last night. The truck will still go into 4WD with front tires pulling, but the light still does not come on. I did test the switch and the 4WD light will come on when I have the wire harness connected and I use my fingers to hold the switch down, but not when the switch is mounted in the axle. With this being said is this a different issue and I still may have a bad ABS sensor? Any insight on further troubleshooting tips would be greatly appreciated. Note I do not think it is the rear ABS sensor since my speed sensor is working.
Edited by striegel.t
