Idle mode PID?
Anyone know if there is an OBD  PID for idle mode? Say for instance my truck had a weird lopey idle and I suspected that the APPS is rapidly jumping from idle mode to off-idle (because the truck also jumps out of fast-idle mode when it's cold). I know I can check it with a meter, but I was hoping I could monitor it from obd.
Thanks.
If it was me I would just change out for a Timbo's APPS being it fully a mechanical APPS sensor and no electronics. Then it a matter of angle to trip the IVS switches than voltage. As long as the angle is right then the IVS should be in the idle position.
TPS should show 0% at idle.
If you've done any voltage adjustment that is what screwed it up. NEVER adjust the voltage of the APPS to match the tag.
On 4/17/2018 at 8:37 PM, Me78569 said:
obdlink will tell you if there is throttle input, but not if the IVS is switching on and off.
Idle state is controlled by another "function" of the apps.
I stand corrected and figured that after postings. Thx
L8tr
D
I still have much to learn
I have a Banks Brake and I don't think the Timbo will work with a Banks, otherwise I'd get one. Haven't made any adjustments, although I've read your info on how to do it properly (I tested the APPS with a meter maybe 4 years ago and everything checked out fine). Still the original APPS after 20 years and 280k miles.
