Boost Leak Tester
A Fernco coupling in the plumbing department of what ever building supply is closet. I forget the size. Just measure the inlet on the turbo and get one that fits. The other needs to fit the PVC fitting you buy. You don't need a gauge in it unless you just want it. I just put about 20 psi or so and started soaping joints. You are after all looking for leaks. I can almost gaurantee you have a leak somewhere.
Thanks for the info.  Will follow up after checking.
They don’t make a Fernco that fits the turbo inlet.  It is just a RCH larger than 4”.  A four inch Fernco fits the O.D. of a four inch pipe, which is about four and a half.
Surely somebody has an idea?
