Anyone have a connection to get EMF ball joints for an 01 4wd 2500 ?
Or feed back good? Bad?
  • Replies 8
  • Views 3.2k
  • Mopar1973Man
    Maybe should try a set of ACDelco Ball joint like I've got going yet after 200k miles. https://www.rockauto.com/en/catalog/dodge,2002,ram+2500+pickup,5.9l+l6+diesel+turbocharged,1440064,suspensio
  • You need to tag him. Hit the @ and then type his screen name. And it looks like this @Mopar1973Man . When you type in a few letters his name will pop up and select it. Or just quote him. He will get a
  • @BBHD did really. Just helping. See above my post.
I'm pretty sure EMF's are splined. Unless you need that feature I would personally not recommend them. Once you go splined you can't go back to a regular joint.
https://www.rockauto.com/en/catalog/dodge,2002,ram+2500+pickup,5.9l+l6+diesel+turbocharged,1440064,suspension,ball+joint,10070
Sometimes you don't have to buy high dollar brand name to get quality.
On 8/8/2018 at 8:55 AM, 01dodge24v5.9 said:
Mopar1973man are you running the professional quality series or the standard series?
X2 ^^^^
1 hour ago, BBHD said:
X2 ^^^^
You need to tag him. Hit the @ and then type his screen name. And it looks like this @Mopar1973Man . When you type in a few letters his name will pop up and select it. Or just quote him. He will get a notifacation.
Edited by dripley
